temp and pressure
Old May 13, 2006 | 07:49 PM
jbusmc1986's Avatar
jbusmc1986
St. Jude Donor '06
Default temp and pressure
my oil press reads 130 psi is that a bad press sensor or what? what is a good oil temp and coolant temp, I think that my car idles hottt like 220 ish
Old May 13, 2006 | 07:59 PM
vette747's Avatar
vette747
The failure of the oil pressure sensor is common on the C5. There are several DIY.
http://forums.corvetteforum.com/show...um_id=1&arch=1
and I also did one on my web site:
http://pages.infinit.net/vette747/IntakeManifold
If you search the forum you will find a ton of thread on oil pressure sensor.
The temp seems normal if idle and AC off. The high speed fans starts at 235 if I recall correctly.
Old May 13, 2006 | 08:08 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
To temp and pressure
