Sway bar question ?
Old May 14, 2006 | 12:07 AM
Cali17's Avatar
Cali17
From: West Hollywood California ! Now Miami, Florida
Default Sway bar question ?
i am looking to get T1 sway bars and my question is, will heavy duty Teflon lined Heim joint end link fit ....?? will they work with T1 sway bars ... or do i need a different end link ??
please advise
thanks a ton !!
Old May 14, 2006 | 01:21 AM
leaftye's Avatar
leaftye
They fit. Just get the same size as stock, they're in standard sizes, and won't be hard to find. You'll also need a bolt with spacers to mount the links on.
Old May 15, 2006 | 03:39 AM
Cali17's Avatar
Cali17
Default ttt
i was going to take it to the shop to have them put them on .. will they have that . or do i have to buy . it and . how much for them . if i do ????
thanks
Old May 15, 2006 | 05:59 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
It might just be easier to but a set of the links from 'Vette Brakes and products. They're $130, I think, for the set of 4.
Old May 15, 2006 | 08:48 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
this is what I used and they work really well.
The problem you will have is finding a T1 bar that will fit a C5. the new T1 bars that came out for the C5/C6 do not fit over any modified exhaust on the C5. There is no bend in the rear sway bars.
The older style T1 bars are NOT easily found.
Old May 15, 2006 | 09:57 AM
leadfoot4's Avatar
leadfoot4
Actually, I forgot to mention that I have them too. If you choose to go this route, make sure that the links are all the same length, at least on each axle. If they're not, strange handling characteristics can happen....Don't ask how I know.
Old May 15, 2006 | 08:47 PM
Cali17's Avatar
Cali17
Default ttt
thanks ..
so far no .. issues with . the order .. so i am keeping my fingers crossed now . !!!
To Sway bar question ?
