EBCM replacement trouble
Old May 14, 2006 | 09:00 AM
Lancer033's Avatar
Lancer033
Default EBCM replacement trouble
It seems like everytime I touch my car I end up in here asking for help on what I thought was going to be an easy job...
I'm replacing my ECBM on my '02 coupe and have followed the service manual up to the point where it says "Separate the EBCM from the BPMV by gently pulling apart until separated."
It ain't moving.
to get the dumb mistakes out of the way: All six screws are out, and the insulator bolts are off so the BPMV is just sitting lose in the bracket.
Thought this was going to be an easy job, any idea what's keeping it together? How much force can these things take? Can I take a screwdriver to it and pry it apart?
Old May 14, 2006 | 09:33 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You ONLY need to remove SIX screws and it should just pop off.
Check your PM. I sent you my number.
BC
Old May 14, 2006 | 10:28 AM
Lancer033's Avatar
Lancer033
thanks for your help.
I owe you a beer sometime.
Keith
Old May 14, 2006 | 11:25 AM
nuch's Avatar
nuch
Mine required some moderate force with a flat screw driver to "POP" off.
I also did not remove the insulator nuts. Does this allow you to tilt the entire unit? Or do the hydraulic brake lines prevent much movement?
Old May 14, 2006 | 12:32 PM
Lancer033's Avatar
Lancer033
the screwdriver trick was what did if for mine too.
The insulator nuts let you pick up the unit a couple of inches, but not much rotation. Next time I would not bother removing them. The only reason I did this time was because I couldn't get it off at first and thought that might help a little -- it didn't.
To EBCM replacement trouble
