Battery cable intermitent
Old May 14, 2006 | 02:22 PM
APZ's Avatar
APZ
5th Gear
Default Battery cable intermitent
On my '03 the red battery cable is intermitent - when I tug gently in or out on the two cables that go into the battery terminal assembly the circuit opens / closes, e.g, the underhood light goes on or off. How do I tighten up these connections - what controls it - it doesn't appear to be the pressure of the thru bolt to to the + battery point.
What is inside the red plastic fitting that the cable enters and is screwed to the battery - a crimped connector?
APZ
Old May 14, 2006 | 02:26 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
APZ
Remove the cable and make sure that it is clean. I flush mine out with WD-40 and then torque it on to the battery terminal (as per the service manual) to 11 ft/lbs. If that doesnt take care of the problem, get a new cable ASAP!
BIll
Old May 14, 2006 | 02:46 PM
APZ's Avatar
APZ
5th Gear
Bill - Were do you think the looseness is at - at the bolt to the battery or rather in how the cable crimps to the connector which is bolted to the battery??
Old May 14, 2006 | 03:14 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If the battery cable bolt is properly torqued to the battery, I would have to say that the removing the palstic cover a little at a time to expose the cable crimp and if that is good the bolt in the center of the cable to see where the problem lies. The plastic does NOT have to be there for the cable to work properly. If you remove the part that covers the cables, it will give you the opportunity to see if the cables are properly swegged in the lead.
BC
Old May 14, 2006 | 03:34 PM
APZ's Avatar
APZ
5th Gear
Bill,
That helps me, thanks. How do you remove the red plastic piece - does it just pull off? You say it is not needed for operation - you then just put the battery bolt through a metal ring connector that was inside the red plastic piece??
Al
Old May 14, 2006 | 03:40 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Al
Remove the cable. Use a razor blade and slice the BACK of the plastic boot up about 3/4 of the way to the bolt area. That will allow you to pull the cover over the area where the wires attach to the positive cable connection. Please take pictures of what you find!
Bill
Old May 14, 2006 | 06:11 PM
servohead's Avatar
servohead
my B+ at the battery was SOOO corroded it broke when I tried to clean it and had to replace the B+ lead! FYI.
Old May 14, 2006 | 06:25 PM
BA2's Avatar
BA2
You didn't say what battery you have, but my guess is that it is a AC/Delco. My advice is pull the battery before the terminal comes of and get an Optima Red Top battery. If it starts to leak (which they do), the brilliant engineers at GM put the computer right under it. I found my problem after the dealer put two AC/Delco battery in but while the computer and cables were still salvageable.
Old May 14, 2006 | 07:37 PM
APZ's Avatar
APZ
5th Gear
The car in question is "box stock" with 2000 miles - hence factory battery and little or no corrosion - when I get back to where the car is located I let you know what I find but I suspect a bad crimp job - no?
APZ
Old May 18, 2006 | 01:59 PM
APZ's Avatar
APZ
5th Gear
Default Fixed it!
Well, I fixed it. I removed the plastic cover over the two crimped wires at the + terminal and inspected the crimp job - it was fine. Then I rebolted the cable to the rotary green **** battery disconnect switch I use w/o the plastic cable cover - added two washers to ensure it bolted up snug and everything seems go. So what was the problem? I'm not sure - maybe before with the plastic cover in place and using the quick dissconnect switch the stack up was such that it was tight ebough. Any guesses??
APZ
To Battery cable intermitent
