**Need help asap** Harmonic balancer bolt install
First, somehow try to be sure the balancer went on very straight.
The actual hub is aluminum, and can score and peel a bit if not started just right. look inside the bore for any shavings being peeled back.
or, if you are really concerned, pull the balancer back off and start over.
This time, heat the balancer to about 250 in your wife's oven, and hang a bag of ice on the crank. makes it much easier to start it.
Assuming all is straight, and it just gets tough (and it does) use another washer and lots of grease on the surface where the washer contacts the balancer and the bolt head. Thiis should make a really big difference, as the washer or bolt head will dig into the aluminum balancer and create a lot of resistance.
The balancer should go on not quite all the way to the end of the crank. The crank should be recessed approx 0.1 inch when it's on all the way.
Whjen I was putting mine on, I used a longer bolt to start it, then switched to a well-oiled GM bolt. I used a 2 ft cheater pipe on an 18 in Craftsman breakover. I got it down to just about one rib short, and it got very tight. I thought sure I had it. But I checked, and the bolt was digging into the balancer a bit, and peeling the metal. I cleaned up the surfaces real well, greased it again, and it went on down.
I probably put 250 lb-ft on my 3 ft wrench (about 80 lbs at the end)
It was a hard pull, great excercise. but the last time, I really felt it when it bottomed - man it just stopped. i have a manual tranny, and
put it in 4th with the hand brake on. There was about 20 degrees of driveline wrap-up before it firmed up on each pass, but I had the hood off, and lots of room.
After you get it seated, chedk that 0.1 recess.
Then you know the next drill - new bolt 50lb-ft, then 140 more degrees rotation, I think. Mark the bolt head and the balancer after you finish, and check them after a few days to be sure all is well.
Good luck,
Wrench
Good luck.
PS: I saw some of the advice on the LS1Tech, don't heat the bolt you could not only weaken it but also make it larger so it binds more. Also, don't put it in with red loctite, you may never get it out again.
Shane
Good luck!
-Ken
With the threaded rod bottomed out in the crank, all the threads in the crank are taking the load, not just the threads on the end.
37 ft/lbs followed by 140 degrees
You need a puller, either home made or store bought, to get the balancer on correctly. Once it is on, then you can follow the procedure in the manual. Unfortunately, your old bolt used for the 250 lb-ft portion of the procedure is toast.
Before you re-install the pulley I would make sure that the the bolt will go in all the way by hand.
It takes alot of force to get it rotated 140 deg.(I have done mine twice now).
My breaker bar was also bending and the car did seem like it was going to move forward.
If you are worried about getting the 140 deg of rotation you could pin the balancer on the crank so you don't have to go through this.
Take your time and good luck!!
let us know how you make out.
And you have a few of the threads stripped.
I guess if it were me, I would not take anny chances, and see if I could save the day without drilling/tapping new threads.
1. I would see if I could tell how many good threads you have, and how deep they go. You might need a slightly longer bolt than the GM bolt, in order to engage all the good threads, but not bottom out.
You will need to engage 5 good threads with the balancer fully on and the bolt tightened for permanrnt use.
Get the final bolt plan worked out - if you need a longer bolt, find one, and get it ready before proceeding.
2. Then I would pull the balancer back off, and be REALLY sure it was clean, not galled, etc;
3. I'd get a tap and really clean the crank threads, then verify my measurements on depth - where the good threads start, how deep, etc.
4. I'd get a threaded rod or long bolt and a nut/washers, as was suggested, and use it to re-install the balancer. Seat it all the way down in the crank, then turn the nut/washer against the balancer, with
plenty of oil/grease on the threads and the washer/balancer interface.
5. After it's totally seated, check the depth measurements carefully, and install the final bolt (probably a slightly longer one).
Measure/measure/measure to be sure the bolt won't bottom out.
Remember it will stretch about 0.050" when you do the final torque.
Summary: Something galled or bound up on the original install attempt.
Find it, fix it before trying again. (pull the dampener).
put it on using a seatred rod and washer (or a real $40 installer).
Get at least 5 threads engaged on the final bolt.
If you can't do these, you may need to drill/tap the crank.
I fixed the stripped crank bolt. Apparently the crank was fine and the crank bolt suffered the most. I cleaned and tapped the crank with an old bolt that i had. When threading the old bolt in I made sure that i could hand tighten the bolt all the way to the balancer hub. So all I had to do is put the new bolt in and torque it to the 250ftlb. Now the car is running and no problems. Thanks guys for all your input. If not I don't know how bad off I would be.
