Off topic car, but please help
Old May 21, 2006 | 12:18 AM
98_corvette's Avatar
98_corvette
Default Off topic car, but please help
I am a corvette owner (98 C5), but use a little 99 mitsubishi mirage to get around as a DD. This is the problem with the DD:
I come to a stop and it slowly starts to shake a bit, then die. I can easily turn it back on again, so the problem is not likely the battery. A kragen employee (only car-related thing open when I went to check) told me it was likely a problem with the "lock cylinder" (he wasn't sure of its exact name). Again, it only dies when I come to a stop, while it is actually being driven, everything feels fine.
Please offer any suggestions
Again, I apologize that this is about a car other than the vette, but I have great trust in forum members, so I thought I'd ask everyone here.
Old May 21, 2006 | 01:09 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Throttle position sensor. sounds like what it is to me.
Old May 21, 2006 | 01:16 AM
98_corvette
Thanks, I read a bit about it, and think it may be that as well.
Old May 21, 2006 | 08:53 AM
c5chines's Avatar
c5chines
Default Stalling
I'd start by running some fuel treatment and doing a spray clean of the throttle body innards. Chuck.
Old May 21, 2006 | 09:41 AM
Jay-rod's Avatar
Jay-rod
Maybe a vaccuum leak,bad gas,dirty injectors,bad wires(was it raining?).Sounds minor,try a visual inspection and if all looks well try fresh tank of fuel and throw some injector cleaner in it and beat on it a little.JER
Old May 21, 2006 | 01:40 PM
dpd's Avatar
dpd
,sounds like a dirty blade and housing.
Old May 21, 2006 | 02:15 PM
Hotrod C5's Avatar
Hotrod C5
6th Gear
I agree. Easy to check. Keep pressure on the throttle, which will maintain a slightly higher RPM. That should tell ya the story. Good luck.
Old May 21, 2006 | 02:42 PM
gamisou's Avatar
gamisou
Is the MIL on. First thing you should do is try to pull the codes. History and current, And start from there. How long has it been since a tune up.
Old May 21, 2006 | 07:03 PM
98_corvette
I do know its been a long while since a tune up (car has 98k on it now), but not sure exactly, but would say at least 2 years. And the check engine light is NOT on. But I am not sure how to "pull the codes." Thanks again for all the suggestions though.
Old May 22, 2006 | 12:50 AM
gamisou's Avatar
gamisou
Most likely you don't have a code but you can gring the car to one of those chain parts stores they will pull the codes for free.Since there is no check engine light, I would go ahead and give it a tuneup. After 2 years it needs it regardless, even if it doesn't correct the problem completely it's a good place to start. Plugs,wires,air-fuel filters,some fuel system treatment,cleaning the throttle body. Also I just noticed you said something about a lock cylinder any more info on that.
Old May 22, 2006 | 07:03 PM
98_corvette
All right. I went down to my local shop and they told me that my fuel injectors and fuel filter were very dirty. They cleaned the injectors and replaced the filter. It seems to be "fine" now (it at least has stopped dying at every red light), but you're right, I should still do a tune up. Thanks to all for your help.
To Off topic car, but please help
