wierd blinker issue
Old May 26, 2006 | 04:36 PM
MonteHall's Avatar
MonteHall
Cruise-In VII Veteran
St. Donor '03 & '06
Default wierd blinker issue
driving to the cruise-in, my turn signals stopped functioning.
however, if I toggled the 4-ways, then my signals would work again for a while. I probably had to do this 4 or 5 times over the 4 hour drive.
ideas?
I was going to get some of this to try and fix it, but he's sold out
http://kalecoauto.com/index.php?main...&products_id=6
Old May 26, 2006 | 05:33 PM
2KVetteMan's Avatar
2KVetteMan
Your hazard switch is starting to fail.
Old May 26, 2006 | 05:34 PM
racetchr's Avatar
racetchr
Its your emergency switch. Same thing has happened to mine twice in 6yrs. Switch is cheap, but you have to install from the top of the dash which means removing the dash pad. Good luck.
Old May 28, 2006 | 04:50 PM
MonteHall's Avatar
MonteHall
St. Donor '03 & '06
any write-ups on this?
Old May 28, 2006 | 05:24 PM
SpeedUp's Avatar
SpeedUp
http://forums.corvetteforum.com/showthread.php?t=860333
To wierd blinker issue
