Gear choices
Old May 26, 2006 | 10:32 PM
70 LS1's Avatar
70 LS1
Default Gear choices
Are 4.11's too much for an M6 street car? Car is 1970 convertible with LS1 and T56. This is a weekend/ fair weather cruiser with no track time. Currently stock LS1 with future mods to only be long tubes and ASA cam.
I am considering 3.90 4.11 and 4.33.
What do you guys think and why?
Old May 27, 2006 | 12:43 PM
70 LS1's Avatar
70 LS1
Anyone?
Old May 27, 2006 | 01:11 PM
unstressed's Avatar
unstressed
If your T56 has the same 6th ratio as the Vette 6 speed, you should have a great combo with 4.11's.
I have 4.10's and run a bit over 2200 RPM's at 80mph if I remember right. 1-5 are really close and get the car moving quickly, but I still get good gas mileage in 6th.
Wish they had 6 speeds when I was a kid. I ran a BB 468 with an M21 and 4.11's. I got around 6 mpg..... yuch.
Old May 27, 2006 | 07:59 PM
70 LS1's Avatar
70 LS1
Yup, ratios are the same as the C5's. Thats why I asked here in the C5 section. With the 4.10's do you find yourself spinning the tires much when you take off or when its wet out?
Old May 27, 2006 | 08:53 PM
unstressed's Avatar
unstressed
It certainly is a bit harder to get a clean launch w/o spinning the tires. It's not that bad though, but if you had big HP, then I could see it as a problem. My measly 330 rwhp do not overpower the tires too bad.
Not sure about wet weather, it's doesn't rain much here.
The big difference for me is that 3, 4, & 5 pulls so much harder now.
It's definately not too much gear, most that have done the swap will say that it should have been the stock ratio.
Old May 27, 2006 | 09:19 PM
70 LS1's Avatar
70 LS1
Cool. Looks like I am leaning more towards the 4.11's.
Hows the weather there in San Diego? I am heading down on Tuesday for a month.
Old May 27, 2006 | 10:18 PM
Jay-rod's Avatar
Jay-rod
Go for the 4.11,s.The first gear ratio in the tranny is tall.It will feel like a 373 off the line compared to your old muncie.
Old May 27, 2006 | 10:27 PM
algZO6's Avatar
algZO6
i say go with the 4:33s. when i had my ws6 i had 4:30s in my 12 bolt and it was a blast. btw this was with 440rwhp and 408 rwtq.
Old May 27, 2006 | 10:36 PM
70 LS1's Avatar
70 LS1
The muncie was
2.52 / 1.88 / 1.46 / 1.00
The T56 is
2.66 / 1.78 / 1.30 / 1.00 / 0.74 / 0.50
Keep the posts coming. Want to hear your experiences.
Old May 28, 2006 | 01:41 AM
unstressed's Avatar
unstressed
Been cloudy lately, but is supposed to clear up Tuesday. It's warm at least.
Old May 29, 2006 | 09:11 AM
PatsLs1vette's Avatar
PatsLs1vette
Hey jeff,with my 3.70's and a hard launch i spin all the way threw 1stand 2nd gear too.I have to feather it coming off the line then get into .But im still gone to change it to probably 4.10's. With your 6 speed it might be worse.
Old May 29, 2006 | 09:13 AM
PatsLs1vette
Ill be swapping to a bigger cam after the summer too ,so that might change my mind on 4.10;s maybe more.
To Gear choices
