Codes ? --- Help Please
Old May 27, 2006 | 09:54 AM
nmbsun's Avatar
nmbsun
Default Codes ? --- Help Please
I have several error codes under 58-SDM and I cant find anything in the search on here.
B 0026
U 1000
U 1016
U 1040
U 1096
Someone Please tell me what these codes mean. Also I have gone to the links that some have posted for the DIC Codes but I cant find what the 58-SDM Code means. Any info on this?
Thank You
PS... This is for a 2004 C5
Old May 27, 2006 | 10:05 AM
PierEagle's Avatar
PierEagle
Go to www.corvettedoctor.com
Click on Technical Data Base, then ECM Computer Codes, then Year.
Or something like that. Will give you all the codes.
Cheers
Old May 27, 2006 | 11:32 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
B 0026
U 1000
U 1016
U 1040
U 1096
Thank You
58-SDM is not a fualt code itself, it is just telling you the next module fault codes displayed will be for the SDM (sensing & diagnositcs module).
The B0026 is a BCM fault code and all of the "U" fault codes I think are loss of communications, the only thing missing is they should have been followed by either an "H" or an "H C" for history or current, either way erase all of them in manual diagnostics by scrolling thru and holding the reset button down to erase the code and see if anything comes back.
Old May 27, 2006 | 11:35 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Is the airbag deployed?
Old May 27, 2006 | 11:59 AM
nmbsun's Avatar
nmbsun
No, But I had the column lock recall done and the column lock plate removed. I suppose that when they took all of it apart could they have left the Air Bag connector loose?
To Codes ? --- Help Please
