underdrive pulley
Old Jun 2, 2006 | 01:15 AM
N0TDADYS_98's Avatar
N0TDADYS_98
Default underdrive pulley
I'm about to do a cam swap... while i'm at it i'm gonna replace spring, rods, oil pump and timing chain... thinking about maybe doing a pulley... My understanding this slows down the other items in the belt system there by freeing up static power.. how does this effect the way those items work? I'm planning on installing a full PC in my dash here soon and will need some juice...
Old Jun 2, 2006 | 06:44 AM
Bounty's Avatar
Bounty
Since you'll need to pull the stock balancer off for the cam swap, this is the perfect time to install the pulley as it's considered "free" labor. There is a brand of pulley (I think SLP) that underdrives the crank, but not the a/c. The a/c belt remains the same. Good for warmer climates that need 100% air conditioning capability at idle and low engine speeds.
As for the other accessories, they are usually underdriven between 15% to 25% depending on brand of pulley. The one I am referring to above is at 20% I believe. My tuner says no issues with charging or engine cooling at idle but YMMV....
Old Jun 2, 2006 | 08:17 AM
George V's Avatar
George V
Look at LPE, they sell a 25% under drive ASP with along with a smaller pulley for the alternator spinning it at the standard speed while slowing down the PS and water pump. Works good, no problems here
Old Jun 2, 2006 | 11:54 AM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Zero problems under-driving your accessories (alternator, water pump, power steering, a/c). Gain is circa 12rwhp
Old Jun 2, 2006 | 12:01 PM
Cgillies86's Avatar
Cgillies86
I have an ASP 25% underdrive pulley and I have no problems with it. Definetly worth it!
Old Jun 2, 2006 | 07:56 PM
Greg_E's Avatar
Greg_E
I regret that I didnt do it when I did my H/C package. I say go for it.
If your interested in the Powerbond / SLP pulley, Dr. Chill is selling them in the "For sale" section at an excellent price. He only has a few left, so if you want one, contact him soon.
Old Jun 3, 2006 | 10:01 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
I did it, but im not sure Id put my money into that mod again.
No down side at all, but im not sure of the up side
Old Jun 3, 2006 | 01:15 PM
da vette guy's Avatar
da vette guy
12 rwhp sure sounds like a lot for only a 25% reduction, anyone with dyno proof?
To underdrive pulley
