Can the side ducts be made functional?
Old Jun 4, 2006 | 12:38 PM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
Default Can the side ducts be made functional?
Has anyone been able to make the side ducts functional to help get heat out of the engine compartment? I have opened up the fog light shrouds to help get ambient air in, but also want to help get the hot air out. Is this reasonable possible using some sort of ducting? Anybody already do it?
Thanks,
Clayton from Las Vegas
Old Jun 4, 2006 | 02:46 PM
6Speeder's Avatar
6Speeder
Easily done. Unbolt the fender liner and you will see a block off panel. I only removed mine on the driver's side. Removing the pass side one exposes the PCM to more water than I wanted or dared.
Old Jun 4, 2006 | 02:51 PM
SilentFright's Avatar
SilentFright
From: Arlington Texas, originally from San Angelo, TX
You can also cut segments out of the hood seal weather stripping (above the firewall) to vent the engine bay.
Old Jun 4, 2006 | 05:14 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Clayton
Yep,,remove the drivers side. You can trim off some of the passengers side to allow some air out but still keep the weather out of the fender well where the PCXM and TAC live. There water tight but no sence adding more water to the area.
There are fender well accesses in both fenders!
Bill
Old Jun 4, 2006 | 06:44 PM
JeffC5's Avatar
JeffC5
From: Edmond, OK...One of the first rules of online forums: If you don't like what is said but can't refute it, attack the poster.
I wonder why they dont leave them open from the factory?
jeff
Old Jun 4, 2006 | 06:52 PM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
jeff
For what it's worth, I ask ET the same question awhile ago and he indicated that testing showed no improvement in engine compartment airflow.
Old Jun 4, 2006 | 08:42 PM
JeffC5's Avatar
JeffC5
Then I'd leave them alone.
jeff
Old Jun 5, 2006 | 01:25 AM
wamara's Avatar
wamara
Cruise-In II Veteran
The side vents are functional- they are open to the engine compartment from the top; the plastic inserts/shields are there, I assume, to protect from water or ???????? I have no idea whether their presence reduces the maximum potential cooling effect, although I recall some racers in the Autocrossing/roadracing section claim their track temps dropped after removing the inserts.
Old Jun 5, 2006 | 03:32 AM
c5vette_dallas's Avatar
c5vette_dallas
get a heat extractor hood
Old Jun 5, 2006 | 06:56 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Wheel well is a high pressure zone so I vent them through there. It was reduce lift and create more downforce. Also vented them on top where it goes out the hood as you see in the picture below.
Old Jun 5, 2006 | 09:28 AM
meldog21's Avatar
meldog21
Looks like air to me.
Dog
Old Jun 5, 2006 | 04:39 PM
Dirty Howie's Avatar
Dirty Howie
What picture.....????
I would like to keep my engine bay cooler at the track without having to replace the hood
DH
Old Jun 6, 2006 | 07:38 AM
jdmvette's Avatar
jdmvette
Night Owl for life
i removed my driver's side and noticed quite a bit of heat coming from it when i parked vs. the other side that was still closed off.
although the passenger has the battery surround shielding the area from the engine too...
Old Jun 6, 2006 | 09:51 AM
yellow01's Avatar
yellow01
The louvers in John's hood are functional, there are cutouts below to the top of the wheel well which vent out the louvers on the side of the hood.
Old Jun 6, 2006 | 01:40 PM
Face's Avatar
Face
Sweet looking setup!
Old Jun 6, 2006 | 06:15 PM
Dirty Howie
Ok...thanks
I would be interested in getting the side vents to be functional but not willing to change the stock hood!!
DH
Old Jun 6, 2006 | 11:05 PM
joemoia's Avatar
joemoia
DH
Howard, the simplest way is to open up the fog light shrouds and remove the hood seal weather striping, I'll show you at WSIR this month
To Can the side ducts be made functional?
Old Jun 7, 2006 | 01:14 AM
Dirty Howie
I have the fog shrouds opened already
I remember reading some reasons NOT to remove the rear hood seal...something about pressure and drawing dirt into the engine bay.
But maybe at least to remove it at the track if its easy to take on and off.
.....I'm looking for any cooling I can get for WSIR...see you there
DH
Old Jun 7, 2006 | 08:32 AM
6Speeder's Avatar
6Speeder
If you are talking about removing the hood seal at the base of the windshield..... I wouldn't. That is a high pressure area and will push air INTO the engine bay at speed. Plus water, dirt, etc. Pull the block off plate in the fender vents. Easy to do, and it works.
Old Jun 7, 2006 | 01:04 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
Where exactly, and what exactly gets removed?
