Reduced Power Mode
Old Jun 11, 2006 | 06:29 PM
pdd000's Avatar
pdd000
Default Reduced Power Mode
car goes into reduced power mode- car sounds wierd like its firing on 3 cylinders. i give it gas and it barely moves. so i shut the car off, cleared the codes, and boom, car starts up and runs fun. i drive another 10 miles and it does the same thing. so i clear the codes and the car ran fine for the rest of my trip. i checked some of the grounds and there all like brand new. the car did have gas from last september in it-dont know if that has anything to do with it
Old Jun 11, 2006 | 09:47 PM
SpeedyZ's Avatar
SpeedyZ
What code(s) was it setting?
Old Jun 11, 2006 | 11:35 PM
pdd000's Avatar
pdd000
ill check when i get home
Old Jun 11, 2006 | 11:43 PM
NICK YOSKIN's Avatar
NICK YOSKIN
St. Jude Donor '08
probably 1120 1221 1220....if so LOOK AT THE CONNECTOR TO THE TPS. those tangs get spread too far open bam .....reduced engine.
worth a look
Old Jun 12, 2006 | 02:22 AM
pdd000's Avatar
pdd000
worth a look
which connector is the TPS?? the one right on the TB?
Old Jun 12, 2006 | 03:16 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Yes, right-hand (passenger) side.
Old Jun 12, 2006 | 04:41 AM
pdd000's Avatar
pdd000
c594 H C came up- rr solinoid- i took the f45 shocks off and put a resitor where the connector is. ill check it tomorrow but would that make the car go into reduced power mode? i checked th TPS connection, looks good
To Reduced Power Mode
