p1221
Old Jun 12, 2006 | 07:34 PM
tsmf's Avatar
tsmf
Default p1221
Have a '97 a4 with triflow exhaust, aftermarket h pipe, no cats, and a blackwing intake as well as an slp maf. Recently getting the usual service traction, reduced engine power codes:
p1221
p1571
I have cleaned all of my body grounds, they were all spotless except for the posts. I also changed the tac unit. I have had all recalls done as well as rewired the column relay. Am about to go ahead and change the throttle control sensor attached to the throttle body.
Any help you guys can give would be greatly appreciated.
Thanks!
Old Jun 14, 2006 | 12:06 PM
tsmf's Avatar
tsmf
Just changed out the tps on the throttle body, and problem solved. No more "reduced engine power", and no more service traction system messages. The unit cost me $48 and took about 20 min. to swap out.
Old Jun 14, 2006 | 12:40 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Man!! I was just about to go into an elabrate TPS swap out procedure! Good Job!!
bill c
Old Jun 14, 2006 | 03:22 PM
123sugey's Avatar
123sugey
Dig
I AM , WHERE YOU WERE !!!!!!!!
I'M CHANGING OUT MY TPS THURSDAY !!!
WHAT A PAIN IN THE NECK !! TRYING TO FIX THE PROBLEM.
OOOPS !! HERE I AM THINKING THAT CHANGING OUT THE TPS WILL SOLVE MY PROBLEM ( I CHANGED THE TAC MODULE, WIRING HARNESS, CHECKED MY GROUNDS AND ALOT MORE - NOT SOLVING THE PROBLEM)
BUT, I GUESS THIS WILL PROBABLY FIX IT
Old Jun 14, 2006 | 10:34 PM
tsmf's Avatar
tsmf
It should, it worked for me and have had no problems since. Also cleaned out the throttle body while i was at it. The car runs and drives 100% better than i can recall. Best of luck.
Old Jun 14, 2006 | 10:36 PM
tsmf's Avatar
tsmf
Bill thanks for all your posts. The one on body grounds was what sparked me to originally clean them all. I am sure I speak for everyone here when i say that you truly are an incredible asset to all.
Thanks!
Old Jun 14, 2006 | 10:37 PM
123sugey's Avatar
123sugey
Dig
thanks
To p1221
