X-Pipe Question!!!
Old Jun 20, 2006 | 10:44 AM
Vicseek's Avatar
Vicseek
Default X-Pipe Question!!!
I own a stock 2000 C5
Right after I bought the car I installed the Borla (T-304 Stainless Steel Rear Section) I loved the new exhaust note at WOT and at cruise however, near idle and low RPM's I notice a hell of a "slurping, gargle" sound. I haven't been able to listen to many other vettes but I just can't stand that crappy sound anymore! I've checked for leaks but have found "NO EXHAUST LEAKS".
My question is will an X-pipe really make a $300 difference in sound?
Old Jun 20, 2006 | 10:53 AM
BlueDream's Avatar
BlueDream
The x-pipe will eliminate about 95% of the "popping/gurgling sound" on deceleration. I found this out from experience myself. I had also changed out the exhaust for the Borla Quad-tip stingers and then later added the x-pipe. Love the WOT sound but the "popping/gurgle noise" on deceleration was tough to handle for me on a daily driver (especially around town).
To me the x-pipe was worth the money.
Old Jun 20, 2006 | 12:20 PM
2004c5's Avatar
2004c5
When you install the X-Pipe do you fail inspection have any warning messages in your dashboard or any issues to deal with what so ever? Basically do I just replace the piping and thats it? I have the Borla Stinger dual tip exhaust.
Old Jun 20, 2006 | 12:45 PM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
Nope...none whatsoever....
Old Jun 20, 2006 | 12:46 PM
brandtdavis's Avatar
brandtdavis
You should not get any codes or fail any inspections because the X pipe goes in after the 2nd set of O2 sensors. You WILL have to cut your stock pipes off to install the X pipe. I found really detailed instructions on the Corsa website. http://www.corsaperf.com
Old Jun 20, 2006 | 01:11 PM
LF97C5Vette's Avatar
LF97C5Vette
What if you like the decel pop or gugrle? Do all high flow cats come w/ X-Pipes to get rid of that? I'm kinda partial to the sounds...
Old Jun 21, 2006 | 10:40 AM
BlueDream's Avatar
BlueDream
That is a personal preference. I kind of liked it too but needed to change it on my daily driver (if it was a weekend only toy I probably would have left it alone.
It is possible to get LT headers that just attach to the stock cats and can leave the stock H-pipe. There is always a way, just have to go outside the normal ordering options to get there.
Old Jun 21, 2006 | 10:48 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
The X pipe will get rid of the famous motor boat sound.
Old Jun 21, 2006 | 03:19 PM
Vicseek's Avatar
Vicseek
Thanks for the info!
Last year when I installed the Borla I didn't think the $300 X-pipe was worth a second thought. However, I must do something to help eliminate the gurgle.. We'll see if it does the trick
Old Jun 29, 2006 | 10:24 PM
Vicseek's Avatar
Vicseek
The X-pipe worked!!!
%95 of the gurgle/motor boat sounds are gone!! I now have a cleaner sounding Vette.
The $212 Borla X-pipe was well worth the money.
To X-Pipe Question!!!
