one sick C5
Old Jun 20, 2006 | 04:39 PM
4THTOY's Avatar
4THTOY
Default one sick C5
I own a 98 coupe that all of a sudden has lit the check engine light, reduced engine power and service traction sys, I checked the codes and found a bunch of them, can anyone tell me what all of this means?
P1074 H C
U1160 H
1064 H C
U 1016 H
B2232 H
2282 H
2283 H
2284 H
2285 H
2286 H
2262 H
2263 H
2264 H
2265 H
B0851
B0856
C1278
Thanks in advance for any help
Old Jun 20, 2006 | 04:47 PM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
good site to bookmark..
http://www.stengel.net/diccodes.htm
Old Jun 20, 2006 | 05:00 PM
FASST LN's Avatar
FASST LN
I would also check your battery very closely. Sometimes they can leak their acid onto the car's computer which is directly below the battery. Additionally, I've heard that weak batteries will wreak havoc on your computer and throw a lot of phantom codes until you replace it with a new battery.
Old Jun 20, 2006 | 06:47 PM
2K14C7's Avatar
2K14C7
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
Bet thats what it is.
Old Jun 20, 2006 | 07:14 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
P1074 H C
U1160 H
1064 H C
U 1016 H
B2232 H
2282 H
2283 H
2284 H
2285 H
2286 H
2262 H
2263 H
2264 H
2265 H
B0851
B0856
C1278
Most of those are HISTORY. The one's with the C at the end are CURRENT.
Old Jun 20, 2006 | 07:20 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
clear your codes and post in the morning
Old Jun 20, 2006 | 09:27 PM
Vette X 3's Avatar
Vette X 3
loss of communication with the bcm is current and there has been a lot posted here about this one... good luck
Old Jun 21, 2006 | 01:45 AM
striper's Avatar
striper
It sounds to me like you are experiencing a battery that is on its way out, they will drive the computer nuts. If it is still the original battery check for leakage underneath when you remove it.
Old Jun 21, 2006 | 04:06 AM
David426's Avatar
David426
Make sure you respond back to this thread and let us know what the problem and fix was..
To one sick C5
