Spring Change Question
Old Jun 24, 2006 | 10:12 AM
Kschwamy's Avatar
Kschwamy
Default Spring Change Question
Am going to change the springs on our 98 and have done the search but cannot seem to find any how too's. Does anyone remember seeing a how to on changing the springs on a C5? Thanks
Old Jun 24, 2006 | 10:56 AM
98C5RT's Avatar
98C5RT
From: Somewhere between the Red and the Rio Republic of Texas
I'm interesting in doing the same, so PM me if someone points you in the right direction.
Old Jun 24, 2006 | 10:59 AM
bigleman's Avatar
bigleman
what springs?
Valve springs?
Suspension springs?
the spring in the pen that comes in the owner's manual?
Old Jun 24, 2006 | 11:12 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
The rear spring is very straight forward, the front is a bit of a pain (you'll neet to disconnect the upper A-arm from their mounts, etc.)
Check out LS1howto.com, lot's of good info there. (here is the link to the pring swap http://ls1howto.com/index.php?article=20)
Old Jun 24, 2006 | 07:27 PM
nwc6's Avatar
nwc6
I recently changed the front spring out on my coupe because one of the ride height bolts seized. I took about 2.5 hrs total. Looks intimidating, but isn’t. Front end alignment afterward is suggested.
Old Jun 24, 2006 | 09:10 PM
jrc27's Avatar
jrc27
Cruise-In IV Veteran
Cruise-In V Veteran
the rear is easy, took me about 45 minutes
Old Jun 25, 2006 | 09:10 AM
Kschwamy's Avatar
Kschwamy
Originally Posted by bigleman
what springs?
Valve springs?
Suspension springs?
Suspension
Old Jun 25, 2006 | 09:12 AM
Kschwamy's Avatar
Kschwamy
Thanks allot.
To Spring Change Question
