All my lights flicker. Need help
Old Jun 25, 2006 | 12:30 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Default All my lights flicker. Need help
Hey guys, I noticed that my headlights and all the dash lights will dim for a split second. It will do it about every 5 seconds. I had it idling and checked the volts with a handheld tester and it reads 13.3 volts even when it dims. Any idea what is going on?
Old Jun 25, 2006 | 04:41 AM
Racer1x's Avatar
Racer1x
Mine was doing the same thing, the battery was weak. I replaced the battery and all was well.
Old Jun 25, 2006 | 04:50 AM
SLPRC5's Avatar
SLPRC5
Check out your ground, clean terminals if needed...good luck Bud..
Rsty
Old Jun 25, 2006 | 02:49 PM
jah13's Avatar
jah13
I had the same issue and it ended up being a loose battery cable. Voltage reading on DIC woul fluctuate as well: cool:
To All my lights flicker. Need help
