Engine Temp
Old Jun 25, 2006 | 10:23 PM
pauly1119's Avatar
pauly1119
St. Jude Donor '06-'11
Default Engine Temp
Hello, what is the normal running temp for a vette in South Fl. Mine is running at 210 to 230, is this normal?
Thanks in advance.
Old Jun 25, 2006 | 10:32 PM
Bruce1899's Avatar
Bruce1899
In Daytona Beach my 99 run 198 - 204. Your's seems a little high to me but lets wait and see what others say.
Old Jun 25, 2006 | 10:39 PM
pauly1119's Avatar
pauly1119
I have seen people have lowered the fan temps, how is this done?
Old Jun 25, 2006 | 10:41 PM
Threed's Avatar
Threed
From: GOCC - Rebels Without A Clue Santa Barbara, CA
Make sure that you check for debris up in the radiator. Pretty common problem.
Old Jun 25, 2006 | 10:44 PM
pauly1119's Avatar
pauly1119
Hello, I did clean the debris out of the radiator a few weeks ago. I had about 2 pounds of junk under there.
Old Jun 25, 2006 | 10:45 PM
towercontroller's Avatar
towercontroller
yea mine was in the area of 215-230 when my car was stock. Now its running around 185 or so with the 160 degree thermostat.
Old Jun 25, 2006 | 10:47 PM
pauly1119's Avatar
pauly1119
was that with a thermostat only? Fans?
Old Jun 26, 2006 | 09:46 AM
VETTING's Avatar
VETTING
When you cleaned did you get in between the a/c condensor and radiator? Also if you change stat to a 160 have a reputable tuner in your area reset the fans. Good luck and Happy Vetting!
Old Jun 26, 2006 | 11:08 AM
AD2VET's Avatar
AD2VET
CI 2-3-4-5-6-7-8-9-10 Vet
St. Jude Donor '09-'10
Mine was starting to creep up, about 5 degrees every week or two until they were topping out in the 230 degree range. I had a leak in the coolant recovery tank so I replaced that and cleaned out around the radiator but it didn't make much difference. Then I replaced the thermostat with a new stock one and everything is back to normal, 198-210 range.
Old Jun 26, 2006 | 04:21 PM
pauly1119's Avatar
pauly1119
Does anyone know a good tuner in the Ft lauderdale area to change my fan temps? Thanks for the help
Old Jun 26, 2006 | 05:09 PM
djengr's Avatar
djengr
On a 100 degree day, on the highway, my A4 runs about 198 with AC on. When in stop and go trafic, same day it can get 225 plus, but cools back down when I get on the highway again. On a bit cooler days it will run about 194 more or less on the highway.
Old Jun 26, 2006 | 06:02 PM
Oldvetter's Avatar
Oldvetter
Both fans come on at around 235 degrees F, so that is normal. You should still check radiator for debris. Also, for "city" driving, if you turn on your Air Conditioner, it will turn on the fans and cool your temperatures.
Old Jun 27, 2006 | 05:00 PM
pauly1119's Avatar
pauly1119
Thanks for the help. My A/C stopped working this week, thats prob. why I noticed the higher temps. Thanks for the help.
To Engine Temp
