Spark plug wire recommendations??
Old Jul 9, 2006 | 10:57 PM
1Corvette's Avatar
1Corvette
Default Spark plug wire recommendations??
With the planned installation of headers in the near future, will I need new plug wires? If so, what is everyone using? I have used MSD in the past and always felt the quality was excellent. Thanks!
Old Jul 9, 2006 | 11:05 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
using MSDs here ...
Old Jul 9, 2006 | 11:14 PM
BadAV's Avatar
BadAV
I've still got the stockers in the Vette but I've got the MSD Superconductors in the Avalanche. They've been in for about 3 years now with no issues.
Old Jul 10, 2006 | 12:30 AM
kiley2418's Avatar
kiley2418
i went w/ lg's
Old Jul 10, 2006 | 10:52 AM
BudgetPlan1's Avatar
BudgetPlan1
St. Jude Donor '09-'10
Unless you break them during the install I don't think you'll see any loss using stock
Old Jul 10, 2006 | 12:14 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The OEM GM wires are fine! If you read them with an OHM Meter and they read between 250-750 OHMS,, there fine! If you really want to up-grade, get the GM high performance red wires. What your looking for in a wire is QUALITY! They should fit properly and be able to stand up to the heat in the engine compartment. As long as they are not burnt, cut or the connectors inside the boots are not corroded, I would save my money for other things. If your old wires are good, spending $50-$200 on new wires will NOT do anything but empty your wallet. You will see ZERO HP INCREASES! Don't get caught up in the hype that some manufactures try to sell you!
I use the magnacore wires and have had very good service from them. I had to replace mine cause they were defective (open conductors causing high resistance). If I had to replace my wires today, I would purchase the GM High Performance (RED WIRES) They use the stock heat shields, are excellent quality and they are not too expensive!
Bill
Old Jul 10, 2006 | 07:56 PM
nuke61's Avatar
nuke61
Originally Posted by Bill Curlee
If I had to replace my wires today, I would purchase the GM High Performance (RED WIRES) They use the stock heat shields, are excellent quality and they are not too expensive! Bill
Do you happen to know the GM part number?
Old Jul 10, 2006 | 10:29 PM
dwjz06's Avatar
dwjz06
Dogface
St. Jude Donor '15, '17
Magnecor. They make a specific header set with 90 degree ends. Best I could find after long research.
Old Jul 12, 2006 | 12:25 PM
Doug@MorosoPerformance's Avatar
0Doug@MorosoPerformance
Former Vendor
Default Spark plug wires
Moroso makes a good set of wires at a reasonable cost. Have had the same set of wires on since I installed headers four years ago on my daily driver.
Old Jul 12, 2006 | 08:54 PM
JAvery20's Avatar
JAvery20
Old Jul 12, 2006 | 10:08 PM
LoneStarFRC's Avatar
LoneStarFRC
Same here.
Old Jul 12, 2006 | 10:22 PM
Tigershark3's Avatar
Tigershark3
I used GM High Performance wires from Fichtner Chevrolet. $49 and the part number is 12495519. And if I'm not mistaken they are a forum vendor. With new plugs it was a nice SOTP boost.
Regards
Old Jul 12, 2006 | 10:50 PM
Vette Ed's Avatar
Vette Ed
CI 4-5-6-7-8-9-10 Veteran
St. Jude Donor '07-'09
received my GM hot wires today #12495519, $49.95 from Bob @
Fichtner Chev - btw, they are RED
Old Jul 12, 2006 | 10:57 PM
jhong321's Avatar
jhong321
I had the msd wires until i burned 1 of them on the header. I switched to the taylor 10.4 (more for the looks) The stock wires will work fine. You might want to get a set of cool socks for your wires just to be safe
Old Jul 14, 2006 | 12:45 PM
rhubarb74roadster's Avatar
rhubarb74roadster
MSD and KoolSox here (with LG Headers)
No issues
Old Jul 14, 2006 | 03:01 PM
csexton's Avatar
csexton
Put them on last weekend along with a set of AC Delco Iridium plugs.
Chuck
Old Jul 14, 2006 | 03:18 PM
willyfastz's Avatar
willyfastz
The MSD 8.5's ohm out at around 26 OHM's so there is deffently a performance advantage over the stockers. 250-750 OHMs is a lot for only 8 inches of plug wire. The Tylor 10.5's that I check ohmed out at 36-38 ohms.
To Spark plug wire recommendations??
Old Jul 14, 2006 | 03:35 PM
ICaughtVetteFever's Avatar
ICaughtVetteFever
Did the same thing.
Old Jul 14, 2006 | 04:29 PM
RED99's Avatar
RED99
Just don't get ACCEL!
Old Jul 14, 2006 | 05:27 PM
vettes4fun's Avatar
vettes4fun
Originally Posted by pewter99
using MSDs here ...
me to with no problems
