AC Question
Old Jul 10, 2006 | 11:51 AM
jarsdad1's Avatar
jarsdad1
Default AC Question
Air cond is blowing hot. Snowflake button flashes. Manual says it does this when the ac cannot operate, but it doesn't give a reason or solution. Any ideas? Thanks
Old Jul 10, 2006 | 01:16 PM
rws.1's Avatar
rws.1
#1 cause of this is low R134a charge...
Did you check for any codes?
http://www.corvettedoctor.com/Code_Main.html
Old Jul 10, 2006 | 03:32 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
CODES! please post the codes.:::
Old Jul 10, 2006 | 03:52 PM
DPG's Avatar
DPG
St. Jude Donor '06
is your temp set low enough for the ac to turn on? also check for codes
Old Jul 10, 2006 | 07:07 PM
jarsdad1's Avatar
jarsdad1
Will do. Just got the car. Learnin' stuff. Thanks.
Old Jul 10, 2006 | 07:50 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
I'm having a problem with my A/C too,Have a code B0361,I know that is the LEFT ACTUATOR FEEDBACK SHORT TO GROUND.But when I press the A/C button it just flashes and goes out,I topped it off with freon,But still does not work.It worked before even with that code.What else can I check?........................Paul
Old Jul 10, 2006 | 07:58 PM
maddogbishop's Avatar
maddogbishop
Default Previous Owner
I am the previous owner of the car in question. The A/C had always worked properly. Before the current owner picked up the car, I put a new Delco battery in. Now the A/C is not operating. Are there some actuators or something that has to be reset when the battery is out of the car for a certain period of time? When he pulls the codes, there will probably be many, being that the old battery went dead. When you try to start these cars with a low battery, all kinds of codes can appear. I am only mentioning this because some of you have requested codes. I am offering this info because I am concerned, and would never let anyone have taken my car if I knew the A/C was not working. I know it worked before the battery change. Any similar coincidences between A/C & battery change?
Old Jul 10, 2006 | 08:22 PM
jarsdad1's Avatar
jarsdad1
Got two codes: 1285 and 1281. DIC says no HVAC codes.
To AC Question
