What's in your tool box?
Old Jul 10, 2006 | 07:12 PM
Dream Machine's Avatar
Dream Machine
Default What's in your tool box?
Inspired by golf articles of a similar title - I am interested in what tools, sockets, wrenches etc. you have in your tool box.
The motivation for my post came this weekend when I jacked up my vette for the first time to:
1). Remove wheels and paint the caliphers.
2). Change the oil
3). Attempted to torque sway bar connections to remove annoying sweaks. Didn't happend as my sockets weren't deep enough and I had the wrong size metric sockets.
Before I go "under again" I want to get the right stuff.
Old Jul 10, 2006 | 07:44 PM
ErnieN85's Avatar
ErnieN85
1/4 metric & english deep sockets also
3/8 metric & english deep also
1/2 metric & english up to1.5 & 36 mm deep also
3/8 breaker bar
3/8 torque wrench
1/2 torque wrench 25-150 lbs
1/2 torque wrench 25-250 lbs
1/2 breaker bar
3/8 flex handle
3/8 t handle
torx bits & sockets to #55
phillips & straight bits
allen wrenches english & metric
drills ac & battery
pop rivet tool
almost forgot box & open wrenches Metric & english
flare nut wrenches
Box wrenches (long) are really handy as they don't round off bolts & nuts as easily!!!
all kind of other stuff picked up over the years (I'm a tool junkie)
Old Jul 10, 2006 | 10:57 PM
Thickraybans's Avatar
Thickraybans
Everything that ErnieN85 has on his list,plus I have found a set of metric gear wrenches very handy.Also,when you buy your socket sets check for skipped sizes,and buy singles to fill out the set. Good mechanics gloves can save alot of hide. White lithium grease on the swaybar bushings usually takes the squeeks away.
Old Jul 10, 2006 | 11:20 PM
Vetter Atl's Avatar
Vetter Atl
Originally Posted by Thanatos
..... White lithium grease on the swaybar bushings usually takes the squeeks away.
Hijack Alert*****
Sorry, but where do you apply the white litium, I ve WD-40ed them all over the out side and it only works for a day or two, or untill it rains.
Old Jul 11, 2006 | 06:26 AM
ErnieN85's Avatar
ErnieN85
Originally Posted by Vetter Atl
Hijack Alert*****
that's only good till it rains try some antisieze
Old Jul 11, 2006 | 07:38 AM
Silver98's Avatar
Silver98
Hijack Alert*****
WD-40 mis NOT a lubricant. I know most of us will occasionally use it as such, but it is a penetrant, designed to aid in loosening stuff.
Old Jul 11, 2006 | 07:41 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Hijack Alert*****
to WD-40. Get some real grease in there...
Old Jul 11, 2006 | 07:50 AM
Wicked Weasel
no matter what you will always need another tool
Besides the standard sockets I found the need for a breaker bar and torque wrench. I also found that a torq #15 dedicated screw driver is very important.
You might want to add 4 rhino ramps, 4 jack stands, 4 wheel chocks and a low profile jack. This will make your life a lot easier when changing oil and doing other things.
I drive the car up on 2 ramps and then lift the front and add 2 jackstands. I then chock the front wheels and go to the back and lift the rear of the car to put the other 2 ramps under them (I face the ramps in the other direction so that it would be hard for the car to roll off). I then add 2 more jackstands.
At this point I feel somewhat comfortable getting under my car
Old Jul 11, 2006 | 08:00 AM
Fastbird's Avatar
Fastbird
Pro Mechanic
C5 of Year Finalist (performance mods) 2019
2017 C5 of the Year Finalist
2016 C5 of the Year Finalist
2015 C5 of the Year Finalist
You will ALWAYS find a reason for a new tool. That said, I have the following:
Full 6 point 3/8 Drive Metric and Standard Socket Set through 7/8" and 20mm, short and long
Short 1/2" Drive M and S socket set
1/4" Drive short and long M and S socket Set
2,3,6,9" 3/8 drive extensions
Screwdriver set
7 Piece Craftsman REversible Ratcheting Wrench Standard Set (You WANT these)
7 Piece Craftsman REversible Ratcheting Wrench Metric Set (You WANT these too)
Craftsman Professional Stubby Wrench Set, Standard
STandard and Metric 7 piece (each) Allen Head Socket Sets
Torx Bit Socket Set, 7 piece
Metric Allen Wrench Set
Standard Allen Wrench Set
Craftsman Digitork 1/2" Torque Wrench
Standard and Metric Boxed End Wrench Sets
Various Pliers, Lock Jaws, Vice Grips, Wire Cutters, ect.
Exhaust Pipe Spreader/cutter set
LARGE c-Clamp for brake jobs
40 Amp battery charger
Large 3 Prong Pulley Puller
Hub Puller
...........that's all I can think of right now. Yes, I do most of my own work. Just waiting for the engine machines.......
Old Jul 11, 2006 | 08:21 AM
AU N EGL's Avatar
AU N EGL
Too much to list
Old Jul 11, 2006 | 08:24 AM
VetteDrmr's Avatar
VetteDrmr
I am interested in what tools, sockets, wrenches etc. you have in your tool box..
Always less than what I need.
Have a good one,
Mike
Old Jul 11, 2006 | 09:09 AM
Smokin Joe's Avatar
Smokin Joe
I just skimmed the post...
what about air tools.
Two air compressors (but not a two stage), impact gun, air ratchet, bead blast cabinet, cutting wheel, air chissel, air sander, ... oh an tire valve stem adapter
I don't have any welders though...hmm.
Old Jul 11, 2006 | 09:37 AM
vet86blk's Avatar
vet86blk
ODB II code reader comes in handy. Just got one this weekend.
Can;t seem to get rid of that damn P0113
Old Jul 11, 2006 | 10:06 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
trying to aquire everything in Sears catalog and then some. It never ends!
Old Jul 11, 2006 | 11:02 AM
1965imp's Avatar
1965imp
Don't forget the inch pound torque wrench.
Old Jul 11, 2006 | 11:14 AM
Billdog350's Avatar
Billdog350
Harbor Freight.com is a cheap and easy way for people to get their tool "quantity" up to snuff...then when you break them you replace the broken ones with "quality" ones like Crapsman, Snap-On or Husky.
I bought a metric large socket set from 19 to 50mm for $35 rather than $400+ at Sears......if I ever break that 3/4" drive breaker bar or one of the sockets, then I'll replace that part with the $20 socket from Sears. You'll need a large metric socket for your rear shocks, its like 24 or 30mm or something like that.
Same goes for lots of the tools that you'll probably use a half dozen times if your life.
However, I'm with the guys above who talk about "gear wrench", those things are the BOMB...mine go up to 25mm! They're costly but worth every penny.
Old Jul 11, 2006 | 11:33 AM
chocoholic's Avatar
chocoholic
Originally Posted by AU N EGL
Too much to list
Bingo. If you lads are able to list what you have from memory, you clearly don't have anywhere near enough tools!
Just for clarification, was the OP's question relating to tools for use on the car that are in the toolbox on the trailer, the toolbox in the back of the car, the contents of the toolboxes in the lock-up, the tools in the spare bedroom, those under the stairs, the ones in the basement, or...?
To What's in your tool box?
Old Jul 11, 2006 | 11:53 AM
ErnieN85's Avatar
ErnieN85
too true however I think the original person was looking for a starting point.
It's a never ending quest
Old Jul 11, 2006 | 01:17 PM
94legaleagle's Avatar
94legaleagle
hijack alert -
try wrapping teflon tape around the swaybar where the bushings go - this is supposed to help w/ squeeking.
Tool wise, I agree, if you can list them from memory, you don't have enough - also agree, you never have all the tools you need for any given project - therefore, "sorry hun, I gotta get this tool, but think of the money we're saving on repairs"
Old Jul 11, 2006 | 01:25 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Too much to list
