installed column lock simu from mad vette
Old Jul 13, 2006 | 08:36 AM
comfortracing's Avatar
comfortracing
Default installed column lock simu from mad vette
and it finally unlocked my steering wheel, but i still get the error message and cant go over 2 mph. the instructions said to remove fuses 25 & 29 or disconnect the battery for 15 minutes then replace. well i disconnected the battery over night and it didnt help. 25 & 29 fuses under the hood are labled "spare" and one is missing. any other suggestions? the 2 fuses they talk about, are they under the hood in the main box or somewhere else?
thanks in advance!
Old Jul 13, 2006 | 09:09 AM
comfortracing
ttt
Old Jul 13, 2006 | 11:47 AM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
The fuses you are talking about are located in the interior passenger foot well.
Old Jul 13, 2006 | 12:39 PM
87SAM's Avatar
87SAM
Were you getting the error message before you installed the CLB?
Old Jul 13, 2006 | 01:05 PM
comfortracing
YES, but the part i bought came with an "unlock" piece so you could install it on an already locked piece.
comfortracing
thanks "tact" i will look there tonight!
Old Jul 14, 2006 | 12:12 AM
HollywoodFRC's Avatar
HollywoodFRC
Default BCM Fuses
When I put in my CLB from Thunder racing instructions had me pull (WITH THE IGNITION KEY IN THE ON POSITION) Fuse #25 in the passenger footwell fuse box for ten minutes to reset the BCM. CLB went in and I am now driving and error free. Keep searching the forum for answers if that doesn't work. Best of luck.
Old Jul 14, 2006 | 06:45 AM
comfortracing
so far nothing is working. i will try that one hollywood. i pulled 25 & 29 without the key in...now i will try it your way.
Old Jul 14, 2006 | 12:37 PM
jdaniel2509's Avatar
jdaniel2509
I reset mine with fuse 25 and the key on. I had to play with it a few times but it finally worked.
Old Jul 14, 2006 | 03:12 PM
comfortracing
i recharged the battery and i had everything working again but the error code was still there so i had it towed
Old Jul 14, 2006 | 03:25 PM
NSTG8R's Avatar
NSTG8R
your car has had the recall preformed .. and now it's sensing its locked.
Old Jul 15, 2006 | 09:12 AM
comfortracing
sure is! so now i am having the "policy" performed by chevrolet to fix the fix chevy already did. in esscence the remove the lock mechinism totally.
Old Jul 15, 2006 | 09:38 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Isn't it amazing that GM is still farting around with this dilema on vettes?Good thing they didn't incorporate this wonderful system on their volume cars like the Cobalts.................
Old Jul 15, 2006 | 02:48 PM
bayarea's Avatar
bayarea
I pulled fuse 25 there and the "service
column lock" message went away
Old Jul 15, 2006 | 04:10 PM
thorn92's Avatar
thorn92
Even if they completely remove the locking system, they still don't seem to cooperate un re-flash the BCM back to normal to prevent us from the possibility of being stranded if I "glitch" signal is sent. That's the trick...getting our cars "driveable" in the event the dreaded error code is triggered for any reason.
Old Jul 17, 2006 | 05:13 PM
comfortracing
i know...this makes me all very nervouS!!!
Old Jul 17, 2006 | 05:34 PM
B84RADR's Avatar
B84RADR
In case this is helpful at all, I just installed my CLB from Thunder Racing last week. Worked like a champ and haven't had a problem since.
Here were my instructions.
Thunder Racing CLB
To installed column lock simu from mad vette
