Please help me with code C1286!!!!!!!
Old Jul 13, 2006 | 10:16 PM
chargedc5's Avatar
chargedc5
Default Please help me with code C1286!!!!!!!
Can someone help me with this code, C1286 Steering Sensor Bias Malfunction. What does it mean and how can I fix it???????
Old Jul 14, 2006 | 08:51 AM
Silver98's Avatar
Silver98
The steering sensor is a ring magnet located at the bottom of the steering wheel. It is used to determine the direction you want the car to go and is checked against the yaw sensors to determine if you are in a skid or not. It produces a +/- 5vDC output from stop to stop on the steering wheel.
It is a PITA to replace since you have to remove the steering column to get to it. That said, however, there is a distinct possibility that it is a ground and not a failure of the part. I would urge you to check, by removing, cleaning and relanding, all your ground connections. My error was corrected with the ground on the rear above the diff and the left front on the chassis. Its been awhile though, so check them all. If you don't have the service manuals for your car, now would be a great time to get them. Unless you're handy and don't mind tearing the column apart, find a dealer you can trust and have them take a crack at it.
HTH,
Joe
Old Jul 14, 2006 | 08:56 AM
chargedc5's Avatar
chargedc5
Thank you for the info, I THINK. It sounds like a long weekend job!!! I will start with all the grounds.
Old Jul 14, 2006 | 04:03 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Most of the time this code results from disconnecting the steering rack, rotating the steering wheel, then reconnected. Any sort of work performed recently that could be related?
Old Jul 18, 2006 | 10:28 AM
chargedc5's Avatar
chargedc5
You are right I did disconnect the steering rack and moved the steering wheel. Did it mess up the sensors and how can it be fixed?
Old Jul 18, 2006 | 07:40 PM
Gordy M's Avatar
Gordy M
You have to measure the voltage at the steering wheel sensor (located at the firewall on the steering post. The voltage in the correct position will be about 2.4-2.6V. The light blue wire is the the one to measure voltage. Be prepared to do upside down twisting to get to it.) More than likely it will read 0.26V or 4.9V or close to it. If it is 0.26V go to the engine bay and disconnect the steering shaft and rotate it 360 deg to the right, if it is 4.9V then turn it 360 deg to the left. Ask me how I know.
Old Jul 18, 2006 | 08:59 PM
chargedc5's Avatar
chargedc5
Thank you, I will try that.
Old Nov 20, 2021 | 12:25 PM
Justin Laurin's Avatar
Justin Laurin
Navigator
HTH,
Joe
Can you list all locations for the grounds, if possible? And above the diff where? Would I have to drop the diff? And left front on the chassis where?
Old Nov 20, 2021 | 04:16 PM
feeder82's Avatar
feeder82
You can find answers a lot easier with you just start a Google search with C5 Corvette, than your question. The first answers that pop up are usually Corvette forum thread's.
Old Nov 20, 2021 | 04:29 PM
grinder11's Avatar
grinder11
What he said........
Old Nov 20, 2021 | 06:54 PM
Justin Laurin
Navigator
I’m starting to realize that now lol. Thank you anyways. These diagrams are a big help.
To Please help me with code C1286!!!!!!!
