How do I fix being limp
Old Nov 14, 2021 | 10:25 PM
MrMcE's Avatar
MrMcE
Default How do I fix being limp
My C5 seatbelts don't seem to retract that last little bit and as a result flop about, possibly sitting in the door jamb and prevents the door from closing completely, including a few cringeworthy moments of closing the door kind of hard on the seatbelt.
On previous cars, a little cleaning of the belt itself helped, but hasn't helped here. Is the retracting mechanism just too old and only a replacement will have it firming up as it once was?
Old Nov 14, 2021 | 10:46 PM
jdmvette's Avatar
jdmvette
Night Owl for life
See here:
https://www.corvetteforum.com/forums...post1601954366
Old Nov 14, 2021 | 11:06 PM
MrMcE's Avatar
MrMcE
Originally Posted by jdmvette
My seatbelt works fine for the most part, though. It pulls out, if I pull it out all the way then it does that annoying ratchet where it only tightens from there. Sometimes after getting into the car, I'll need to feed the belt back in a little bit before it can be pulled out. So pushing in still works whereas your guide is to fix it once that doesn't work.
Old Nov 14, 2021 | 11:21 PM
jdmvette's Avatar
jdmvette
Night Owl for life
Good luck then
Old Nov 14, 2021 | 11:32 PM
MrMcE's Avatar
MrMcE
Not sure what the eye roll is for, did your guide include something about maybe reindexing the belt or have any insight as to why it stops retracting at like 90%
Old Nov 15, 2021 | 12:56 AM
RC81's Avatar
RC81
Was going to say every radio station and tv show commercial has the answer to your problem, then realized it was about something else. Not sure how you'd get a retractor to swallow a pill lol.
Old Nov 15, 2021 | 06:24 AM
dskinsler83's Avatar
dskinsler83
The annoying ratcheting is made for locking the belt for track use.
Old Nov 15, 2021 | 05:45 PM
Mikado463's Avatar
Mikado463
at first I was going to recommend Viagra, but now I see it's a belt issue ........
Old Nov 16, 2021 | 09:42 PM
aaronc7's Avatar
aaronc7
Is the DIC malfunctioning as well?
Old Nov 16, 2021 | 09:54 PM
MrMcE's Avatar
MrMcE
I have a minor issue with the rubber over the dic controls but I think I have good grasp on the dic issue
Old Nov 17, 2021 | 02:21 AM
Tusc's Avatar
Tusc
Running Guns & Moonshine
Haven't had that problem. But my gf is 12 years younger than me, so I have a leg up on keeping the propane flowing.
Old Nov 17, 2021 | 09:46 AM
epimetheus-lee's Avatar
epimetheus-lee
If you are having seat belt wear issues, I would recommend sending them to to Safety Restore in MA. They clean and lube the retractors and they replace the worn seat belt webbing. Plus you can choose from a variety of webbing colors. They are very good and very fast. Mine returned to me in Colorado within a week. Yellow Vette on You Tube has a good R&R video on the the removal and replacement. BTW, if you subscribe they send you a discount coupon for your first order.
Old Nov 20, 2021 | 08:14 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
"I have a minor issue with the rubber over the dic "
That's what HE said...
"I have good grasp on the dic issue"
That's what SHE said.....
Old Nov 20, 2021 | 08:34 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
"How do I fix being limp"
Uh oh...........maybe Viagra ? .........
Old Nov 20, 2021 | 11:13 AM
Mikado463's Avatar
Mikado463
I suggested that ! (post #8)
Old Nov 20, 2021 | 09:22 PM
Yello95's Avatar
Yello95
St. Jude Donor '11
Sorry, I keep forgetting that only one person on earth can recommend a similar answer at any given time...forgive me master...1
" at first I was going to recommend Viagra, but now I see it's a belt issue .."
btw...you recommended(not suggested) it then changed your mind so I reintroduced it...thanks for your understanding...
Old Nov 20, 2021 | 10:45 PM
Mikado463's Avatar
Mikado463
no problem, I thought you might have suggested Cialis !
Old Nov 21, 2021 | 12:01 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
To How do I fix being limp
