AFR Heads - Any Surprises?
Old Jul 14, 2006 | 12:59 AM
Cscokd's Avatar
Cscokd
Default AFR Heads - Any Surprises?
Just got mine yesterday and discovered my 1998 valve covers won't work because the heads require center mount valve covers. Are there any other little surprises ahead of me as I install them? Rockers, pushrods, headers, intake manifold, coil pack mounts?....what else is lurking around ahead of me here? Thanks to any of you that have gone ahead of me here.
John
Old Jul 14, 2006 | 05:59 AM
vettenuts's Avatar
vettenuts
I believe the centerbolt coil brackets are different as well. Not sure if you can adapt them. The biggest surprise will likely be the permanent smile pasted on your face one the car is running with the heads
Old Jul 14, 2006 | 06:10 AM
AU N EGL's Avatar
AU N EGL
with the right cam, OMG
Old Jul 14, 2006 | 07:58 AM
vettes4fun's Avatar
vettes4fun
Old Jul 14, 2006 | 08:02 AM
willyfastz's Avatar
willyfastz
You will need the coil pack brackets as well. Other than those two things you should be good to go.
Old Jul 15, 2006 | 12:48 AM
Cscokd's Avatar
Cscokd
OK, so now I need a set of valve covers...grrrr...anybody have some stockers you want to lose?
John
To AFR Heads - Any Surprises?
