is this common
Old Jul 17, 2006 | 12:01 AM
brogden31's Avatar
brogden31
Default is this common
I just got my c5 and when i start it you can hear a noise sounds like loose rockers then it goes away is this common?
Old Jul 17, 2006 | 12:04 AM
JamMasterJ's Avatar
JamMasterJ
St. Jude Donor '06
Called piston slap... unfortunately it is common.. not to worry. Not much ya can do.
Old Jul 17, 2006 | 03:57 AM
dudleyd's Avatar
dudleyd
My guess is a lazy lifter. Mine doe's the same thing. All's good for the first min. or so then it starts ticking, after about 2 or 3 min at idle all is nice and quite.
Old Jul 17, 2006 | 10:27 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
www.pistonslap.com
Old Jul 17, 2006 | 06:11 PM
David426's Avatar
David426
Piston slap.. Very common on these cars. Starts at about 130 degrees and goes away at 170 degrees I was pissed when I first heard it on mine, but learned to ignore it after awhile. It will not affect performance or longevity of the engine... Just annoying. Get headers and a Borla Exhaust system.. You won't hear it..
Old Jul 17, 2006 | 07:32 PM
dudleyd's Avatar
dudleyd
If I understand screw991le attached link then the noise should have been there from day one due to sh**y tolerencing of the pistons. Mine started at about 100K and is just a little ticking sound. I'll be throwinig on a new set of heads/cam/rockers and pushrods in a few weeks, while I was in there I was going to change out the lifters to so that should tell the story. I don't know, maybe my noise is not what brogden31 has.
To is this common
