shift light
Old Jul 18, 2006 | 08:00 AM
glennxx1's Avatar
glennxx1
Default shift light
im wondering if you can get a shift light and wire it in, JUST a shift light, im not sure if you need like a MSD box to do that but i dont think you do, ive seen some guys advertising some where just a shift light
Old Jul 18, 2006 | 08:11 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Most people here run the raptor. Check out Xtreme Motorsports, they are a supporting vendor who sells them
Old Jul 18, 2006 | 08:20 AM
glennxx1's Avatar
glennxx1
ty, just curious, (have yet to do any mod on a C5 that required runing wire through the firewall, is there any fairly easy wholes to get to?)
Old Jul 18, 2006 | 09:57 AM
TmillerC5's Avatar
TmillerC5
St. Jude Donor '08
Chexk out this thread. Very helpful.
http://forums.corvetteforum.com/show...2&page=1&pp=20
Old Jul 18, 2006 | 10:40 AM
bandit_99's Avatar
bandit_99
Raptor... I'll be installing mine tomorrow night with the instrucs in the link above this post.
Old Jul 18, 2006 | 05:48 PM
glennxx1's Avatar
glennxx1
what would be difficult about wiring it to the white wire? just getting to it?
Old Jul 18, 2006 | 06:14 PM
briann510's Avatar
briann510
My tach wire on my 03 was right here and very accesible in the upper passenger footwell. I also had a extra key on only power/ground pigtail under there also grab power (sure beats trying to tap in somewhere else). shift light took about 15 minutes to install with the only hassle trying to tap into the white wire as there isnt much slack in it.
I pushed the tach wires to the other side right through the console on top of the carpet using a small wooden dowel which took a whole 10 seconds.
Old Jul 18, 2006 | 06:46 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Going to install mine this weekend also. I will try to take some pics.
BC
Old Jul 18, 2006 | 06:51 PM
muncie21's Avatar
muncie21
You can also tap the tach and power wires under the dash, if you don't want to run your wiring across the car.
Old Jul 18, 2006 | 09:35 PM
bandit_99's Avatar
bandit_99
Isn't the pink wire in that group the power?
Old Jul 18, 2006 | 09:37 PM
briann510's Avatar
briann510
Not sure on the pink wires in that group as I had a extra power pigtail right out in the open to use. I would think 1 pink might be power while others might not be, just like only 1 white wire out of 5 possibles is the tach wire.
Old Jul 18, 2006 | 10:00 PM
bandit_99's Avatar
bandit_99
ahh, you went in the footwell- I was actually looking at the other picture and thinking it was yours. The other pic only showed one pink wire- but there are probably others in there.
Old Jul 18, 2006 | 10:25 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Raptor here, but I wired it to the PCM.
Old Jul 18, 2006 | 10:58 PM
Miguels's Avatar
Miguels
I just fixed mine...I had some bad connectors.
Wire twisted the wires together solved everything.
I used the Pink wire, which is the 12V switched, the Orange is 12V constant.
I used the large steel metal left of the steering column, you can see the black screw in the opening.
White wire was easy to find as well.
Old Jul 18, 2006 | 11:00 PM
Miguels's Avatar
Miguels
Whoa, you probably got lucky that the white was on top...that is alot of wires.
To shift light
