doors wont un lock
Old Jul 19, 2006 | 12:00 PM
Ralph Young's Avatar
Ralph Young
4th Gear
Default doors wont un lock
doors wont unlock when key is remove. had it to the dealer replace key switch and then the BCM but is no better I thank the dealer has give up.
Old Jul 19, 2006 | 01:53 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Ralph
Do you have any DTC codes displayed in the DIC?? Do the locks work when you try to use the FOB or the switch on the doors??
What year car is it??
BC
Old Jul 19, 2006 | 03:15 PM
Ralph Young
4th Gear
Default doors wont unlock
2003 key fob works ok door switch works ok no codes
Old Jul 20, 2006 | 01:35 AM
PierEagle's Avatar
PierEagle
Don't mean to offend but I've met some dealer mechanics who try to find a solution before they understand the problem. So I have to ask, do you have the "auto unlock" set in the "options" menu?
Old Jul 20, 2006 | 09:37 AM
Ralph Young
4th Gear
auto unlock is set to unlock with removel of key, can the ground problem cause this not to work all of the time, I talked to the dealer he said there would be more problems if it was the ground. the car has
31k have been happy with the car. this is my 4th corvette my son has 2000 and daughter has a 2004.Thank you for Reply Ralph
Old Jul 21, 2006 | 06:33 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Ralph
If the ground to the door module or the door module were bad, the doors would not work with the other devices. There have been several forum members that have had similar issues but also have other symptoms. One possible source of the problem is your ignition key cylinder switch. When that switch inside the ignition switch goes bad, the BCM doesn't know that the key has been removed, thus the sequence of events that happen when you remove the key, doesn't happen. Some of the things that you will experience when that switch goes bad are:
Door open chime/key in ignition occurs when the key is removed.
If you have the memory package, the seat fails to retract when the key is removed (if memory is turned on.
Give that idea a thought and let me know how you make out.
BC
Old Jul 21, 2006 | 07:51 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
......didn't Stephen King make a movie about this?
Old Jul 23, 2006 | 10:04 PM
Ralph Young
4th Gear
dealer has replaced the switch cylinder the first time did not help. the car has the window valet and a xm radio installed could this be the problem
Ralph
To doors wont un lock
