Z06 maf question
Old Jul 22, 2006 | 02:24 AM
da vette guy's Avatar
da vette guy
Default Z06 maf question
any HP advantage of using a 2002 Z06 maf (has no screens) on a regular 2002 a4 that has a few small mods ? anyone ever do a dyno or a track test?
Old Jul 22, 2006 | 02:34 AM
BQuicksilver's Avatar
BQuicksilver
Cruise-In III Veteran
Cruise-In IV Veteran
Interesting question. I'd like to know as well.
Old Jul 22, 2006 | 12:15 PM
da vette guy
i guess we'll have to wonder by ourselves
Old Jul 22, 2006 | 03:28 PM
da vette guy
i always ask the most popular and best questions.
Old Jul 22, 2006 | 06:35 PM
da vette guy
test,test,.............................. ..... is this microphone on?
Old Jul 22, 2006 | 09:06 PM
da vette guy
now i know how a comedian feels when he tells a joke and no one laughs,........... kinda like that loving look you got when you bought your wife a washing machine for her birthday
Old Jul 22, 2006 | 10:16 PM
Tact's Avatar
Tact
Former Law Dawg Moderator
CF St. Jude Co-Organizer
St. Jude Donor '05 thru '24
I bought mine a vacuum cleaner. You should have seen that look I got.
Old Jul 22, 2006 | 10:58 PM
da vette guy
bet you got lucky that night didn't you.
Old Jul 23, 2006 | 01:01 AM
steponc's Avatar
steponc
St. Jude Donor '14
Default MAF Screen
Removing the screen was a popular mod awhile back. I bought and installed a Granatelli intake system. From the front scoop to the throttle body. I called Granatelli about the MAF because it was screened. The explanation I was given is the screen helps stabilize the air flow as it crosses the hot wire of the MAF. I can't tell you if this is true or not.
Old Jul 23, 2006 | 12:20 PM
da vette guy
this comes from GM without a screen on the 02 Z06s
Old Jul 23, 2006 | 08:45 PM
CNB's Avatar
CNB
I use this MAF on my setup simply because it flows more air. However, I don't think it is worth it on a near stock car.
Old Jul 23, 2006 | 08:59 PM
da vette guy
i am curious if anyone has tried one at the track or on a dyno and what difference did it make?
Old Jul 24, 2006 | 11:48 AM
DirtyRed's Avatar
DirtyRed
The screen itself is not that restrictive. It's there to straighten out the airflow before it gets to the wires. A descreened maf on a stock engine would prob yeild .5hp and require a bit of tuning. Not really worth the headache. A stock Z60 maf would require less tuning but still needs to be done for minimal gain. You could go with a Speed Density Tune and get rid of the Maf altogether.
Old Jul 24, 2006 | 08:16 PM
da vette guy
i think speed density is a little radical in view of my minimal mods. if i picked up only 1 or 2 Hp with a Z06 maf that would be fine as long as i didn;t lose any drivability or lose HP.
Old Jul 24, 2006 | 08:53 PM
billiardcue's Avatar
billiardcue
Do you run MAFless?
If so what are the pluses and minuses?
Old Jul 24, 2006 | 10:47 PM
BQuicksilver
Originally Posted by billiardcue
Do you run MAFless?
I run MAFless
Plus:
You can tune within closer tolerances since you don't have the computer sorting between two sets of instructions.
You have an easier job tuning since you can concentrate on one table.
You don't have to worry about wierd MAF issues.
Minus:
Your tune better be right since you lose one of the checks and balances in the stock tuning.
Old Jul 25, 2006 | 04:33 PM
fdxpilot's Avatar
fdxpilot
Originally Posted by BQuicksilver
I run MAFless
Plus:
Minus:
How does an SD tune react to extreme changes in temp and altitude (i.e. air density)? I know a MAF can adjust somewhat for these changes.
To Z06 maf question
Old Jul 25, 2006 | 06:22 PM
EStreeter's Avatar
EStreeter
The screen on the MAF smooths and straightens the flow of air coming into the sensor to minimize false airflow readings. On LS1 engines in vehicles with straight intakes like the C5 the screen isn't necessary. On trucks with the LS1 that have a side tube where the intake air comes at the MAF at an angle the screen is needed to smooth out the turbulance.
GM figured this out and removed the screen from the Z06 in '02.
My guess is there may be some cross model use of the same MAF sensor and therefore the screen is left in as a default.
Remove it or leave it, although if removing the screen is good for the Z06 it should be good for the other C5 siblings.
Old Jul 25, 2006 | 06:46 PM
fdxpilot's Avatar
fdxpilot
Supposedly, the MAF tables in the PCM on the Z are slightly different, to account for the missing screen.
Old Jul 25, 2006 | 07:41 PM
99 vett babycar's Avatar
99 vett babycar
unless you're going to change your intake manafold and do some other extensive mods the answer to your question is the minimal gains you'll see are not worth the expense. Leave your screen right where it is.
