New Clutch doesnt work!!!
Old Jul 28, 2006 | 09:00 AM
patton's Avatar
patton
St. Jude Donor '09
oh yea . a question. did you change the line from master to slave? look in line [master cylinder side ] there is a rumor of a restrictor . its supposed to slow clutch action.which in turn goes easy on drive train. there is a [drill mod] to open it up . it lets clutch opperate faster. look and see if possible tanks alot
Old Jul 28, 2006 | 03:15 PM
minytrker's Avatar
minytrker
Yep, all new and I also did the drill mod.
Old Jul 28, 2006 | 03:45 PM
patton's Avatar
patton
St. Jude Donor '09
was it at master end? what sid drill bit ? drill till its through 1/4 in size.?
Old Jul 28, 2006 | 06:45 PM
minytrker's Avatar
minytrker
yep, did all that....looks like it was the remote bleeder. will know tomorrow when i have it back together
Old Jul 28, 2006 | 06:57 PM
craig04c5's Avatar
craig04c5
Old Jul 30, 2006 | 04:28 PM
minytrker's Avatar
minytrker
Default Update
Took the remote bleeder off and got double the travel in the slave cylinder now BUT the clutch still doesnt work. Im call RAM tomorrow morning. Any ideas, I can't be the first person to not have a clutch work right. I even had two guys come by and help who have done 20-30 ls1 clutches and they are both lost on this one. They suggested changing the master first then changing the slave.
Old Jul 30, 2006 | 06:29 PM
Dope's Avatar
Dope
Resident moron
Did you bench bleed the master first? I'm pretty sure this is necessary prior to installing on the car. I may have missed it in your post.
Dope
Old Jul 30, 2006 | 07:15 PM
RAFTRACER's Avatar
RAFTRACER
Some clutches require a larger bore clutch master cylinder such as the McLeod piece. An adjustable rod on the master cylinder will not create more movement at the slave cylinder, just a different clutch pedal location or "engagment" point. It's a fluid displacement thing. I think the McLeod master cylinder is 1/16 larger in bore diameter so the slave cylinder will move more per clutch pedal travel. Some SPEC clutches will require this , but I am not sure about the type you have installed because I have never used them. I learned the hard way, clutch engagement point was near the floor........good way to tear up your transmission. Hope this helps.
Old Jul 30, 2006 | 11:36 PM
minytrker's Avatar
minytrker
This clutch doesnt require a differnt master. Im am taking everything back out and calling RAM and going to try to send everything back and get all new parts. Between myself and all the people that have looked at my car we have close to 100 clutch installs, so we are ruling out installer error. There are several little things that just are not just adding up right that hard to explain. I will post up after I talk to RAM tomorrow.
Old Aug 3, 2006 | 09:54 AM
minytrker's Avatar
minytrker
Default Clutch Update
RAM emailed me today and said I had a bad hub, they are putting in a new hub and I will have it back tmorrow.
Old Aug 3, 2006 | 10:01 AM
patton's Avatar
patton
St. Jude Donor '09
what was bad on hub? was it hitting flywheel bolts? i told you that you would get it right. now that you are an expert on clutch r+r ing people will be seeking youre help. i got ya bookmarked
Old Aug 3, 2006 | 10:04 AM
HONDAFIXER's Avatar
HONDAFIXER
I've seen where the hub of the clutch disk is too long causing the throw out bearing to hit it. When it hits it will not compress the pressure plate
Old Aug 3, 2006 | 10:16 AM
  #33
see5's Avatar
see5
I would be more than a little grumpy with having to do it over.
Old Aug 3, 2006 | 11:23 AM
  #34
minytrker's Avatar
minytrker
This makes #3 try at it. Im pretty sure the FRC clutch I do next weekend will be much faster.
Old Aug 7, 2006 | 02:07 AM
  #35
minytrker's Avatar
minytrker
Default Update
I got the clutch back from RAM, it had a bad hub which was not allowing the clutch to disengauge. They said it looked like it messed up during the install because they could see marks on it or something. They said for $40 they would put a new one in. I really did not want to have to pay for the repair on a clutch with zero miles on it but they did bump me in front of everyone and got the me the clutch back in one day. After 1.5 months of the car being on jack stands I just wanted to get put together. I put the new clutch in on Sat and it works like a champ.
Old Aug 7, 2006 | 08:55 AM
  #36
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Glad to see that you got your vette back together. Always sucks when you get a defective part and you do not know it until it is too late and you have to do the job all over again.
