Another successful story...
Old Jul 23, 2006 | 03:17 PM
Phil97SVT's Avatar
Phil97SVT
Default Another successful story...
A fellow member of the corvette forum had contacted me a couple weeks back about retuning his 200x Z06. He complained about driveability, idle and lean issues that existed after one very well known florida tuner and a somewhat well known tuner from down south. Basically the car wanted to surge pretty bad @ idle and buck under cruising in the <1800 RPM range. We had talked about letting me tune the car and as always if your not happy with the tune you we don't charge you.
We got started about 12:00 and installed the wideband and started setting up my custom tables. I upgraded the Operating system to Real Time Tuning so I could show him exactly what we changed and how the car responded. Well after we tuned the first table and set the base parameters driveability was 80% better. No idle surging, you could cruise @ any RPM down to 900 and felt smooth, and WOT fuel changed from 14:x to 12.85(slightly rich for road racing). Needless to say he is very happy with how the car drives now. I guess it goes to show you don't need a dyno to perfect the tune.
Phil
Old Jul 23, 2006 | 03:30 PM
Dave68's Avatar
Dave68
Good job, Phil. I saw a guy gain 10 RWHP in between dyno runs by tweaking the software. That was all the proof I needed that tuning does work.
Dave
Old Jul 23, 2006 | 03:42 PM
Phil97SVT's Avatar
Phil97SVT
Dave
Yeah, the correct tuning always helps. We had to remove a 1/4" hole in the TB before we could get it to idle correctly.
Old Jul 23, 2006 | 03:55 PM
Geneus's Avatar
Geneus
Hmmm...I wonder if this was an EB Z-06?
Old Jul 23, 2006 | 04:47 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
Im a witness
but I dont kiss and tell
Old Jul 23, 2006 | 04:51 PM
mdhmi's Avatar
mdhmi
Drilling holes in the TB seems like a copout. It's a shame how few tuners really know what they're doing.
Old Jul 23, 2006 | 05:50 PM
Phil97SVT's Avatar
Phil97SVT
I'm not telling....
Phil97SVT's Avatar
Phil97SVT
Yeah, they use a earthquake sized hole and the stock RAF.
Old Jul 23, 2006 | 05:52 PM
USMUSCL's Avatar
USMUSCL
St. Jude Donor '05
Hey Phil...check your PM
Old Jul 23, 2006 | 06:02 PM
Geneus's Avatar
Geneus
I'm not telling....
Well, you don't have to, as I'm a pretty good guesser. Perhaps you can attribute it to my geneus...LOL.
Old Jul 23, 2006 | 06:19 PM
stano's Avatar
stano
Phil
Good job Phil!!
Old Jul 23, 2006 | 07:32 PM
WKMCD's Avatar
WKMCD
Once again!
Old Jul 23, 2006 | 10:12 PM
dbhajek's Avatar
dbhajek
Hi all, I am the owner of the car Phil is talking about. Phil pretty much hit it on the nose with the before and after.
I really thought I went to big with my cam choice (F13 230-232 595/585 112) and even started to dread driving my car, but the 40 minute drive home after my Phil tune was really enjoyable even though I hit heavy traffic, infact I cant wait to go for my next drive. The difference is really big and now I know why people say the tune can make or break your cam choice. The price of the tune was worth every penny.
Thanks Phil, I have falling in love with my car again.
Old Jul 23, 2006 | 10:18 PM
Steve Theodore's Avatar
Steve Theodore
Well done...I love these types of "success" stories.
Old Jul 24, 2006 | 12:16 PM
ArKay99's Avatar
ArKay99
Sounds like a Moates. Been thinking about this route. If it is, it looks like a winner here.
Old Jul 24, 2006 | 12:21 PM
ArKay99's Avatar
ArKay99
With LS1Edit, a lot of guys think that's pretty much all you can do since you don't have access to the ETC Throttle Area Conversion parameter or the IAC Effective Area table. However we were able to take a Z06 and get the RAF table tweaked well enough that we were able to eliminate the hole. It can be done if you take the time and have the right scan tool.
Old Jul 24, 2006 | 01:34 PM
Phil97SVT's Avatar
Phil97SVT
Its from HPtuners and there is nothing to add aside from a new operating system you burn to the VCM.
To Another successful story...
Old Jul 24, 2006 | 01:35 PM
Phil97SVT's Avatar
Phil97SVT
Actually we don't even tweak those tables. We use RAF and the ETC scaler. The RAF is 90% of the idle issues and the idle can be nailed down in less than 5 minutes.
Phil
Old Jul 24, 2006 | 02:46 PM
ArKay99's Avatar
ArKay99
Phil
As far as tuning, I' m learning that the more I learn the less I know and the more I need to learn. But that doesn't stop me from tweaking. Thanks for the clarifications.
Old Jul 24, 2006 | 03:12 PM
Phil97SVT's Avatar
Phil97SVT
I'm not 100% sure but I can check my tune .cfg but to calibrate the ETC Scaler you log MAF vs Dynamic Airflow and adjust the ETC Scaler to make the numbers and curves match. I usually log both and export to a spreadsheet, avg and find the difference than multiply. The Running airflow is used for idle, basically leave the TB alone and add 3-5 to the numbers for a H & C Combo. Watch the LTIT and STIT in N and adjust from there. Basically you want the LTIT and STIT 0'd so if it tells you its adding 1.75 grams of air per second than add that to the temperature corresponding to the ECT sensor.
Phil
