Guys my comp is showing 6 dtc's i just looked them up but if anyone of you have experienced these problems let me know what you did to resolve them other than going to a mechanic.
my mechanic will be looking at it in a week or so.
po172 Fuel trim system rich bank 1
po175 - bank 2
po300 Misfire detected Spark plug burnt out??? not sure?
p1870 Transmission component slipping
the car has ported heads., g5x3 cam , big fuel injectors, headers, tuned,
A vacuum leak will cause the first three on your hit parade. Also, if the tune is too rich that would do it also, so the vacuum leak is assuming the tune is OK. Did he turn off the misfire detection at idle and low speed for the cam?
