Stereo Question
Old Jul 26, 2006 | 12:47 PM
GOTHAM VETTE's Avatar
GOTHAM VETTE
Default Stereo Question
Quick question about the C5 Bose stereo. Are they like the old Bose Stereos for the 4th Gen Camaros? with the externally amplified speakers?
Reason for asking is that my stock 10 disc doesn't work and rather than replace that I would like to install and in dash CD player and then later on change the speakers. Will this work or do you need to change deck and speakers at the same time??
Old Jul 26, 2006 | 02:06 PM
brogden31's Avatar
brogden31
Default here you go
i just changed mine out the only problem that i had was the gm wire adapter i got from wal mart didnt have the memeroy i ran one off the fuse box but no there are no amp like the c4
Old Jul 26, 2006 | 02:40 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Yes some of the older, Camaros, and Caddys CD changers will work on the Vette. I do not know the part # of the other changers, but do a search and you'll find it.
Old Jul 26, 2006 | 05:16 PM
fej's Avatar
fej
Head over to the Audio/Electronics section and check out the C5 faq .. lots of info there. The stock bose, or as us audio people like to refer to it as blose, system is not very friendly to upgrades or additions. Generally speaking to do anything outside of a factory drop in replacement you need an adaptor or an external amplifier or aftermarket speakers.
There is a member who is working on a write up that will just replace the headunit and leave the rest of the system intact using an adaptor to make it all work.
G'luck
Fej
Old Jul 26, 2006 | 09:48 PM
atsugidad's Avatar
atsugidad
Try this link http://www.discountcarstereo.com/detail.aspx?ID=378
You are Looking for the GMCRV1 which will interface an aftermarket head with the installed Factory BOSE System. It's made by SOUNDGATE. www.soundgate.com
Phil
Old Jul 26, 2006 | 10:47 PM
Sick Z06's Avatar
Sick Z06
Phil
+1 PAC, Metra, and MOST other "aftermarket" car audio suppliers have this harness as well. In the long run, ME being an AudioPhile.. just rip out the speakers, run GOOD quality wire to an amplifier, and install a good quality head unit. But that's me.. and I haven't rip'd out my Blose system yet....
To Stereo Question
