Bilstein Shocks Install
Old Jul 26, 2006 | 06:39 PM
Fat Finger's Avatar
Fat Finger
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Default Bilstein Shocks Install
I will be installing Bilstein Sports shocks on my coupe. I currently have the F45 suspension package. Is there any thing I should be concerned about before I start the install? Any problems that may arise after the install?
Thanks.
Old Jul 26, 2006 | 06:45 PM
VetteSiNz's Avatar
VetteSiNz
I use this info to install my Bilstein Sports Shock: http://www.c5forum.com/diy/shocks.php
Old Jul 26, 2006 | 09:30 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
You'll need a Tech-2 to disable the F45 sensors, or you'll have codes galore, and the car will go into reduced-power mode.
Asterisk means option is enabled.
Old Jul 26, 2006 | 10:33 PM
Jeff Jeff's Avatar
Jeff Jeff
Buy some zip ties. Compress the shock and zip tie it to keep it compressed. Cut the zip tie when you get it in position. Makes the job a lot easier.
Old Jul 27, 2006 | 06:35 AM
Vette_Fan's Avatar
Vette_Fan
Would he need to "corner balance" the car after changing to Bilstein shocks. I'm hearing a lot about that lately... (just wanna know, cuz I'm about to do this mod too)...
Old Jul 27, 2006 | 07:11 AM
Fat Finger's Avatar
Fat Finger
Corner Balance??? What's that???
Old Jul 27, 2006 | 08:05 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
lets just say you dont need to corner balance your car at all. It is something that people do that track a lot.
If you are going to get the car aligned then corner balancing is not much more money so you might want to do it then.
You will not need to corner balance or even get an alignment with new shocks as long as your car was aligned properly before.
That being said I took my car in and it was way out of alignment....
Old Jul 27, 2006 | 08:07 AM
Wicked Weasel
http://www.dietersmotorsports.com/te...nerbalance.htm
or
http://www.elephantracing.com/techto...nerbalance.htm
What is corner balance?
Corner balancing is the process of shifting the weight carried by each wheel to approach optimal values. Although some weight can be shifted between wheels by physically relocating parts of the car, the corner balance process is focused on shifting weight by adjusting the suspension spring height. Any relocation of parts should be performed before corner balancing begins.
Why corner balance?
A properly corner balanced car will handle evenly in left and right turns. Unbalanced handling occurs when front-to-rear weight distribution is not equal for left and right sides.
In a symmetric car out-of-balance is easily understood as excessive weight carried by one pair of diagonal wheels resulting in a teeter-totter affect. If the imbalance is extreme, one of the light wheels may be completely off the ground even at rest!
Street cars are rarely corner balanced and typically have no provision for adjusting spring height. That's because their spring rate is relatively low, perhaps 100 lbs/in. With such low spring rates it would take a huge imbalance in spring height to have a significant affect on corner balance.
Performance and race cars may have spring rates of 300, 400, 500 lbs/in and higher. Corner balance becomes much more important due to the high spring rates - small changes in height greatly impact weight carried. Additionally, we are much more concerned with handling and performance with race cars so corner balance becomes very important.
Old Jul 28, 2006 | 06:44 AM
Fat Finger's Avatar
Fat Finger
Thanks guys!
Any other hints or commets??
Old Jul 29, 2006 | 04:56 AM
Vette_Fan's Avatar
Vette_Fan
Where did you buy your Bilsteins from, and how much..
Old Jul 29, 2006 | 02:48 PM
97vettec5's Avatar
97vettec5
I bought mine from Turner Motorsports and paid 312.39 shipped. I also have the HDs and lovem. Another option is to buy the f-45 simulators (from LS1Speed.com) in place of using the tech 2, I had to do this cause I couldn't find any dealerships around Kansas City that knew how to turn it off. Now I'm in the process of trying to find a good tuner close to me, wish me luck on that one, ha.
Old Jul 29, 2006 | 09:17 PM
Fat Finger's Avatar
Fat Finger
Where can I get one? How much money are we talking about?
I've read on another forum that the simulators on ls1speed.com will do the job. I've also read that I can use the Bilstiens without doing anything else and just ignore the DIC messages. Speed will be limited to 80MPH. I don't like this option.
Somehow, I feel I didn't do my homework on this mod. I read so many posts about members buying aftermarket shocks for their cars but not many post on what to do about the BCM programming.
Still looking for solutions.
Old Jul 30, 2006 | 10:23 PM
Fat Finger's Avatar
Fat Finger
Ttt
Old Jul 30, 2006 | 10:58 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
It's too much $$ for a backyard mechanic:
http://www.ntxtools.com/network-tool.../otc-3628.html
If you can find a friendly dealer tech, they should be able to do it for you.
Old Jul 31, 2006 | 10:38 AM
Fat Finger's Avatar
Fat Finger
Man, you aren't joking! I hope the GM dealer here on Guam has this puppy. If not, it looks like I'll be selling a set of Bilstien shocks!
Old Aug 1, 2006 | 09:20 AM
striper's Avatar
striper
All GM dealers have to have one. That is what they use to diagnose problems. They cost about $3k. Due to a fortunate occurrence I happen to have my own. I guess you are a little too far to stop over.
Old Aug 1, 2006 | 09:43 AM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
Can you find a tuner somewhere and send them your PCM to just have it turned off?
Just an idea
Old Aug 1, 2006 | 07:40 PM
Fat Finger's Avatar
Fat Finger
striper, I understand it a fairly straight shot over the Arctic Circle from Guam to NJ. There should be enough driving time to see if I can pin my speedo! I'll try to be there before dinner!
To Bilstein Shocks Install
