Headlight Question
Old Jul 26, 2006 | 09:26 PM
atsugidad's Avatar
atsugidad
Default Headlight Question
I have a HEADLIGHT That is not going up and down as it should and the motor runs with no movement part of the time.
I understand that the gear is probably shot and intend to order the newer Brass replacements soon.
Have a question tho.
Is the gear on the motor itself also Plastic (NYLON) or is it Brass? If plastic - does it need replacing too?
Thanks,
Phil
Old Jul 26, 2006 | 10:58 PM
Sick Z06's Avatar
Sick Z06
I haven't had the oppotunity to take one apart yet, but I would offer this as my words.... If your getting a gear box rebuild set, replace ALL the parts now, or do it again in the future.
Old Jul 26, 2006 | 11:23 PM
napacruzerc5's Avatar
napacruzerc5
The gear is nylon. You can buy brass gears for the headlight motor. See most larger vette vendors: MidAmerica, WCC, CorvetteAmerica to name a few.
Old Jul 27, 2006 | 08:50 PM
atsugidad's Avatar
atsugidad
I know the stock Big Gear is NYLON and as I said I plan to replace it with BRASS. Was wondering about the small gear that's on the end of the motor shaft. (I've never had one apart either)
The BRASS GEARS sold by MID AM and others don't indicate a 2 gear (Big and Small) set, only the one big one.
So again - Is the small gear also NYLON or METAL??
Phil
Old Jul 27, 2006 | 09:12 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
metal...and here http://forums.corvetteforum.com/show...589&forum_id=1
Old Jul 27, 2006 | 10:55 PM
atsugidad's Avatar
atsugidad
Originally Posted by pewter99
Thanks for the info. Just what I needed.
Phil
To Headlight Question
