3:42 Diff.
Old Jul 27, 2006 | 08:05 PM
SLPRC5's Avatar
SLPRC5
Default 3:42 Diff.
Someone has the answer.
Why is the ZO6 3:42 better than the C5 3:42; is it because of stronger shafts?
Thanks,
SC5
Old Jul 27, 2006 | 08:27 PM
Mike Mercury's Avatar
Mike Mercury
Thanks,
SC5
no; not the shafts.
The Z06 gears are shot-peened to make them a little stronger.
Old Jul 27, 2006 | 08:40 PM
SLPRC5's Avatar
SLPRC5
Originally Posted by Mike Mercury
no; not the shafts.
OIC...C5 3:42 would be fine for a DD with the MODS I have? Please see sig.
Thanks,
SC5
Old Jul 27, 2006 | 10:19 PM
Mike Mercury
I run with the non-Z06 3.42 in a 2002 A4:
remember that the manual tranny Z06 has one helluva torque factor due to it having (and being able to dump) a clutch. Unless you go with a full race high-stall TC with drag radials... the Z06 diff should be more that enough.
(but this is free advice )
Old Jul 28, 2006 | 12:13 PM
Jackal's Avatar
Jackal
No difference between the Z06 diff and the coupe diff. The trannys are different. The MN6 in the coupe and the MN12 in the Z. Not only are the mn12 gears a little stronger but they are also geared ALOT better than the mn6.
Gear LS1/MM6 LS6/M12
1st 2.66:1 2.97:1
2nd 1.78:1 2.07:1
3rd 1.30:1 1.43:1
4th 1.00:1 1.00:1
5th 0.74:1 0.84:1
6th 0.50:1 0.56:1
Old Jul 28, 2006 | 01:37 PM
SLPRC5's Avatar
SLPRC5
Ok, so that is why it's better to get a ZO6 3.42 over a C5 3.42 to use with the A4 tranny.
SC5
1st 2.66:1 2.97:1
2nd 1.78:1 2.07:1
3rd 1.30:1 1.43:1
4th 1.00:1 1.00:1
5th 0.74:1 0.84:1
6th 0.50:1 0.56:1
Old Jul 28, 2006 | 01:58 PM
Mike Mercury
source ?
Old Jul 28, 2006 | 02:04 PM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
1st 2.66:1 2.97:1
2nd 1.78:1 2.07:1
3rd 1.30:1 1.43:1
4th 1.00:1 1.00:1
5th 0.74:1 0.84:1
6th 0.50:1 0.56:1
I do believe that the Z06 ring and pinion are shot peened. Otherwise there is no difference.
As far as transmissions go, I don't think that the MN12 ratios are better for my car, I've got a 4:10 rear. It would make 1st gear very, very low. I can start out in 2nd gear now without a problem. Can you explain how a MN12 trans is stronger?
Bob K.
C5XTASY's Avatar
C5XTASY
no; not the shafts.
Old Jul 28, 2006 | 03:42 PM
Blow Torch's Avatar
Blow Torch
Me too; Read it several times from different sorces
Old Jul 28, 2006 | 03:54 PM
Jackal's Avatar
Jackal
Bob K.
I was speaking in regards to an M12 with a 3.42. I currently have an MN6 with a 3.90 rear and it is AWESOME, and I agree that an M12 with a 4.10 is pretty crazy, but people have done it. On the M12 being stronger I dont know, I got my words mixed up, I know the gears on the Z06 REAR are shot peened, I dont know if the tranny is stronger.
Old Jul 28, 2006 | 06:51 PM
SLPRC5's Avatar
SLPRC5
sounds good to me..built strong to last...
ttt
Old Jul 28, 2006 | 07:10 PM
happa's Avatar
happa
Yea a 4:10 with a M12 is CRAZY!!! My buddy had it in his coupe, took the 4:10's out cause it was a little TOO CRAZY! I thought it was awesome but thats just me.
Old Jul 29, 2006 | 01:36 AM
SLPRC5's Avatar
SLPRC5
WOW!!!!
Old Jul 29, 2006 | 02:37 AM
fdxpilot's Avatar
fdxpilot
Actually, if you look at the Tremac specs, T56s with 2.97 1st gears (like the M12), all other things be equal, have a lower torque capacity.
To 3:42 Diff.
