Which TSP Torquer 2 cam. PLEASE LOOK
Old Jul 30, 2006 | 10:33 PM
my 00 vette's Avatar
my 00 vette
Default Which TSP Torquer 2 cam. PLEASE LOOK
I have a A4 2000 coupe. Putting on TSP Stage 1 Z06 heads and have 2 cams to chose form a torquer 2 on a 112 or 114. I want it to be able to be tuned to drive it. Very little track. Drive around town and on the highway. Don't want it to stall or have issues. A nice sounding idle would be cool but if it doesn't run right then that would not be good. Which do I buy?. I have a 3200 stall, a built tranny and all of the bolt ons. Please tell me a 112 or 114. TSP Will be doing a mail order tune. Plus the car runs a 150 wet shot. Thanks.
Old Jul 30, 2006 | 10:50 PM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Either one would work well with the proper tuning. The 114 might slightly be more benificial with your stalled auto, especially if theres alot of city driving.
Old Jul 30, 2006 | 11:06 PM
my 00 vette
thanks keep them coming. Since it's not a track car the best around town and highway driving makes more sense.
Old Jul 30, 2006 | 11:16 PM
tjwong's Avatar
tjwong
Just a small reminder a cam is one instance that more is not necessarily better. I have dyno tuned many LSx engines. And I can show where a smaller cam will often out pull a much larger cam until the upper RPMs will the larger cam out pull the smaller cam. In most cases the smaller cam can have as much as 20hp over the larger cams un RPM ranges under 5500 RPM. I am talking about cams such as the popular Thunder racing TR224 vs a Futural F13 or similar larger grinds. The larger cams will often peak more at the upper RPMs but one has to also ask the question "how often will I be above 6000 RPM" More often the answer is not too often will I be at 6000+ on the street.......
Old Jul 31, 2006 | 09:19 AM
my 00 vette
Very well put. I will keep that in mind.
Old Jul 31, 2006 | 10:32 AM
Billdog350's Avatar
Billdog350
does anyone have a nice comparison with dyno charts from the same dyno/tuner with a bunch of cams on a given motor/tranny combo?
I'd love to see the curves on the TR224 vs the MS3 vs Torquer 2 vs .....
I want big hp/torque gains from 1500-6000 but I could care less about revving it out all the time....
Old Jul 31, 2006 | 11:18 AM
Turbosixx's Avatar
Turbosixx
What gear do you have? If you have alot of gear you could get it on a 114 lsa, less gear like me and get it on the 112. The 112 will "chop" more than the 114 at idle. TSP should get you a good idle with either one.
Old Jul 31, 2006 | 11:44 AM
Face's Avatar
Face
Since you have a A4, the 114 will be easier to tune. Plus, the spray will like the 114 better.
Old Jul 31, 2006 | 12:22 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
I have been told to treat N20 like F/I in this aspect
Old Jul 31, 2006 | 01:26 PM
Thickraybans's Avatar
Thickraybans
The 114 will give a smoother idle,but will shift the torque curve higher in the rpm range. Installing the cam with a couple
degrees advance will help bring the curve down a little. I run a slightly more agressive grind than the torquer,
and with a good tune your cam should drive just fine.Have fun modding.
Old Jul 31, 2006 | 02:21 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Just the opposite. A 112 will move the torque curve higher, and the horsepower curve. 112 will also be narrower. The plus of the 112? You will make more peak power with a 112 than a 114.
The 114 will give you more power under the curve. Both will give you a nice chop - but the 112 will sound more aggressive.
Both Face & Connecticut are correct
Old Jul 31, 2006 | 03:04 PM
myblackC5's Avatar
myblackC5
Default cam
good advice!
Old Aug 1, 2006 | 01:10 PM
my 00 vette
ttt Any more help?
Old Aug 2, 2006 | 05:03 PM
my 00 vette
ttt
Old Aug 2, 2006 | 09:37 PM
Mike94ZLT1's Avatar
Mike94ZLT1
I have the Torquer 2 on a 112, and all I really have to say is I LOVE it!
Old Aug 3, 2006 | 09:25 AM
Huckzilla's Avatar
Huckzilla
Old Aug 3, 2006 | 09:49 AM
CYA-Vett's Avatar
CYA-Vett
If you can't decide between the 112 and 114 why not get 113? Thats what I did
Old Aug 3, 2006 | 09:28 PM
my 00 vette
TSP Orig recomended the 113 but they sent a 114 and then we were able to get a 112. The 113 was not available.
Old Aug 9, 2006 | 12:44 PM
my 00 vette
ttt any more
To Which TSP Torquer 2 cam. PLEASE LOOK
