roll cage question
Old Jul 31, 2006 | 03:09 AM
big dutch's Avatar
big dutch
Cruising
Default roll cage question
i am thinking about getting a roll cage but i am having a problem figureing out if i can fit in the car after one is installed. its a 2000 FRC and i am a 6'5" 270 pound guy.
Old Jul 31, 2006 | 07:23 AM
AU N EGL's Avatar
AU N EGL
Do you have a racing seat ?? a Kirkey 17" seat that sits 1/4" off the floor.
That helps with some room
Old Jul 31, 2006 | 08:16 AM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
The only thing you would have a problem with is your seat movement back. You lose about an inch of back travel with a properly built cage. You should be ok on the sides.
Old Jul 31, 2006 | 08:30 AM
big dutch's Avatar
big dutch
Cruising
cool thanks guys that helps out.
Old Jul 31, 2006 | 11:21 AM
vbrett2843's Avatar
vbrett2843
6th Gear
Default Wolfe Race Craft Roll Bar
I got mine from Wolfe Race Craft in Alrington, Tx. Call them
and talk to them about the fit. They are the "Top Dogs" for cages
in Texas. Here is the link and you can look at my home page to see mine. http://www.wolferacecraft.com/ My Home Page
http://www.vbretting.com/
Last edited by vbrett2843; Jul 31, 2006 at 11:24 AM. Reason: Add Link to Home Page
Old Jul 31, 2006 | 01:25 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Hurm.... here is a much better cage....
Old Jul 31, 2006 | 04:21 PM
SpeedyZ's Avatar
SpeedyZ
That is a nice looking bar! Is that ECS? The only problem I see with that is I wouldn't fit in that car! Looks like it is going to loose at least 4" of seat travel. Looks like a lot of work going on there, that thing is in almost as many pieces as mine!
Is that bar welded right on the frame? Or do they weld something on the frame then weld the bar to that?
Old Jul 31, 2006 | 04:30 PM
0EG@EnglandGreen
Supporting Tuner
You lose about an inch of seat travel, that's all.
It's a 6 point and all 6 points are directly welded to the chassis. I have not welding it in yet - that is not the final location. The swing-up side bars are also not in yet.
It's a custom chrome moly cage. Contact Cajundude for pricing and other details
Old Jul 31, 2006 | 05:26 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Custom 6 point You lose roughly an inch of travel in the seat.
Old Jul 31, 2006 | 05:32 PM
SpeedyZ's Avatar
SpeedyZ
I understand , I was looking how far that cross bar was in front of the rear pan. My seat always sits all the way back against the back pan. I was thinking there would be no way I would ever fit in something like that.
Is this Grond?
Old Jul 31, 2006 | 10:10 PM
big dutch's Avatar
big dutch
Cruising
hey thanks guy. but what about hip and sides of the legs
Old Jul 31, 2006 | 10:52 PM
Cajundude's Avatar
Cajundude
If your body extends past the sides of the seat you may have a problem. The side bars run right next to the door. The bar would run below your knees so you wouldn't hit it there.
Old Jul 31, 2006 | 11:18 PM
0EG@EnglandGreen
Supporting Tuner
Originally Posted by SpeedyZ
Is this Grond?
Yes.
Old Jul 31, 2006 | 11:37 PM
big dutch's Avatar
big dutch
Cruising
ey thanks guys.
Old Jul 31, 2006 | 11:45 PM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
May I slip in a question? How fast does a car have to run in the 1/4 before a cage is required?
Thanks,
Clayton from Las Vegas
Old Jul 31, 2006 | 11:54 PM
big dutch's Avatar
big dutch
Cruising
hey thanks guys.
To roll cage question
