service traction control
Old Aug 2, 2006 | 02:12 AM
vettestyle's Avatar
vettestyle
6th Gear
Default service traction control
hope some one can help. i hit a small bump and the abs active comes on if it is more than one consecutive bump it will turn the traction control light on and service traction control.i was wondering if the module under the right front tire is dirty or wet.it started after i clean the drain behind the battery, and it only does it when the right side hit a bump.(the car keeps running perfect just the light its on) thank you
Old Aug 2, 2006 | 08:27 AM
cliff_ford's Avatar
cliff_ford
Pull the DTC and post. Most likely you have bad female connectors on the front speed sensor harnesses.
Old Aug 2, 2006 | 08:43 AM
Silver98's Avatar
Silver98
What year is you Vette? It maybe a loose / dirty ground connection. If you have the rear mounted EBTCM, there is a ground point near the Left Rear wheel well. Also, check the 'pigtail' connector which plugs into the bottom of the EBTCM. Sounds like its loose.
Old Aug 2, 2006 | 09:02 AM
DeeGee's Avatar
DeeGee
Bill Curlee posted a great write up of a fix. It involved cleaning a number of connectors and solved his problem. I tried a search but its not coming up. I have a copy if you want it
If the problem occurs when going over a bump it may well be the connector causing it.
Old Aug 2, 2006 | 11:16 AM
vettestyle's Avatar
vettestyle
6th Gear
the vette its a 97. just like your silver 98 pic.i will check the locations in the afternoon. thank you for your information. i will let you know
Old Aug 3, 2006 | 11:44 AM
vettestyle's Avatar
vettestyle
6th Gear
i found the problem,in the passenger side back tire the clip that keeps abs, traction control connector away from the axel came loose and the wires broke by touching the spinning axel.
Old Aug 3, 2006 | 12:11 PM
JC in XTC5's Avatar
JC in XTC5
As complicated as these cars are, it seems that most issues tend to be minor things related to wiring or connectors.
Good to hear this was another simple fix.
To service traction control
