Optima Redtop - DBS
Old Aug 2, 2006 | 03:51 PM
C5X2C's Avatar
C5X2C
Default Optima Redtop - DBS
About a month ago I experience DBS on my 5 year old C5. Makes sense, 5 years = new battery. Not knowing any better I tried to jump start it and even at 2500 RPM the beast wouldn't light. I put in a new Optima Redtop and sure enough the car had no juice this morning. One month and the battery is dead! Not even the clock would display. WTF?
I guess I'll pull the battery and see if it has power, take the car in to the dealer for a charing issue??
Not fun!
Old Aug 2, 2006 | 04:43 PM
vettenuts's Avatar
vettenuts
My AGM went toes up recently as well, I did the Exide Orbital.
Old Aug 2, 2006 | 05:37 PM
Wt99C5's Avatar
Wt99C5
Where can you get Exide batteries ?
Old Aug 2, 2006 | 05:47 PM
RubberBill's Avatar
RubberBill
St. Jude Donor '11-'12-'13-'14-'15-'16-'17
Not fun!
Jump Starting a C5 is a NO NO, so I have been told. Causes all kinds of electrical issues.
Old Aug 2, 2006 | 06:27 PM
vettenuts's Avatar
vettenuts
Go to their web site, they will list the dealers near you by zip code. A lot of them don't carry the orbital from what I found.
Old Aug 2, 2006 | 06:38 PM
50th year's Avatar
50th year
2017 C7 of Year Finalist
Ebay has excide.
Ron
Wt99C5's Avatar
Wt99C5
Old Aug 2, 2006 | 07:26 PM
c4cruiser's Avatar
c4cruiser
There have been a number of threads in both the C5 and C4 sections in the last few months about Red Top batteries not lasting.
I had to replace a Delco AGM battery in my 02 a couple of months ago and it was only 2 years old. I went with a standard AC Delco wet battery.
Just curious, but have you checked the electrical system for an abnormal current drain? There is some drain because of the various systems that must be powered up, but a battery only lasting a month is suspicous.
Old Aug 2, 2006 | 07:33 PM
LV Vette's Avatar
LV Vette
St. Jude Donor '08
Not fun!
You can just take the car to Autozone or Sears for a free alternator check. Mat be something as simple as that.
Good luck,
Clayton from las Vegas
Old Aug 2, 2006 | 07:39 PM
HIGHRPM's Avatar
HIGHRPM
I went through 2 red tops and 2 yellow tops..... if you run them all the way down the plates sulphate and cause permanent damage. Quality control on Optimas isn't what it used to be years ago.... I'll never use one again. I'm using a Delco....no problems.
Old Aug 2, 2006 | 07:46 PM
Sherpaboy's Avatar
Sherpaboy
I must have gotten the last good red top I have had mine since last spring never been charged and it sat for as long as a month during the winter with out beeing started no issues with red top here
Old Aug 2, 2006 | 08:23 PM
army6741's Avatar
army6741
red top,two years old never a problem and car is only driven 200 miles a year.
Old Aug 2, 2006 | 08:55 PM
leadfoot2's Avatar
leadfoot2
Have to replace my 3 yr old red-top because it won't hold a charge for more than a few days even with local driving.
Old Aug 2, 2006 | 10:23 PM
GUSTO14's Avatar
GUSTO14
Default Looking for Orbital?
Beiter Battery... 2 day delivery (Florida to North Carolina)...
http://www.beiterbatteries.com/orbital/orbital.htm
Very informative site regarding batteries as well.
GUSTO
Old Aug 2, 2006 | 10:52 PM
johninar's Avatar
johninar
A friend put a Red Top in his AE just 3 weeks ago. It went belly up last week. Mine has been in for 4 months and no problems yet. He went to the dealer and had the electrical system checked out... $80 later he learned the battery was bad. I would go to a Red Top dealer and get the battery checked out first. It appears there is a real problem with Optima. Way too many reports of batteries failing early. Good luck.
Old Aug 2, 2006 | 10:57 PM
Dave68's Avatar
Dave68
GUSTO
1-year warranty????? Say it isn't so......
Old Aug 3, 2006 | 08:02 AM
GUSTO14's Avatar
GUSTO14
Exide's warranty varies depending upon the battery you buy, but for the Exide Select Orbital
this is the warranty...
http://www.exideworld.com/products/a..._84_specs.html
re: Exide Select Orbital Sealed VRLA (AGM) Automotive Battery - 84 Month Warranty 12..
You can go to their website and get information on any of their line of Orbital batteries...
http://www.exideworld.com/products/t...utomotive.html
GUSTO
To Optima Redtop - DBS
Old Aug 4, 2006 | 02:16 PM
C5X2C's Avatar
C5X2C
Perhaps it's just me,,,,,,,,,,,
I found the ground to be a bit loose but the bolt was real tight. I cranked to bolt very hard and the ground was tight again. No charging and I back on the road. We'll see what happens in a while..
Old Aug 6, 2006 | 09:20 AM
ILM-Express's Avatar
ILM-Express
MFIC
You can get them at NAPA !
That is were I got mine
Old Aug 8, 2006 | 07:23 AM
Shifty's Avatar
Shifty
Its a shame that Optima's quality sounds like its on the decline. Some batteries are defective. It's good practice to always get your old battery checked before buying a new one. I found out once the hard way, that my alternator was slowing dieing, causing my battery to run out of juice.
