Head info?
What are the differences between the ‘Stage’s that are advertised for some heads, like ‘stage 2.5’. I assume that there are no hard rules, but that there would be some loose standards as to what each stage would encompass.
I know the AFR 205’s are great, lots of people have good luck with them and no real complaints about them. However, I’d like to find out some more info as I may not want to go with the AFRs, but than again I may.
What about valve size? Are there significant differences in different heads, or will they be in the same neighborhood?
How do the CNC’ed LS6 heads compare to the LS6 heads or the AFR 205’s?
Valve sizes do dramatically affect flow as well as porting. Stock LS1/LS6 valve sizes are on the order of: 2.00” for the intake and 1.55” for the exhaust. For some good stock head data read here. For some good ported head data comparisons, read here.
As far as comparing CNC LS6 heads vs others, it still depends on the purpose of the CNC port design. The port design could be for out all racing trying to maximize flow at say .700” lift. To accomplish this may hurt low end performance, but for a drag car who cares. However, it would not be realistic to compare a head like that vs. stock LS6 heads because they have two completely different purposes.
The good news is you have tons of choices today and many of them are very affordable. Much of it will depend on your specific objectives and goals.
FYI, we had a set a L92 heads (the heads on the new 6.2L engine) hand ported, and achieved the following results:
Flow Numbers – SF1020 Bench, 4.125” bore plate Lift Int Exh .100 80 58 .200 155 114 .300 230 151 .400 285 180 .500 325 200 .550 341 210 .600 352 216 .650 360 220 .700 365 226
Anyone want to chime in on the GMPP CNC'ed LS6 heads, a link, some info or comp to AFR 205's?
I made 480rwhp well over 4 years ago with a 383, those heads, and that cam. For most people, it is a bit much in a stock cube motor, but definitely a head turner when you crank it up.
Many people have doubted these heads over the years because of port size, but GM did their homework.There have been some good results with AFR's. They are definitely on the more costly side. Talk to Tony about cam recommendations. They have some specific recommendations that have produced some very nice results.
We sell both.
We sell both.
For instance, a cam + bolt-on f-body with an M6 put down 370/366 with the ASA cam (slightly smaller than the Grand Am). You can also try searching for "ASA" or "Hot Cam". I would say mid 300's with cam only and upper 300's to 420's+ with cam and heads depending on the rest of your setup.
Hot Cam: 219/228 .525/.525 112
ASA Cam: 226/236 .525/.525 110
Grand Am: 239/251 .570/.570 106
We have many kits ranging from ~$400 to $2k+. PM sent.
