Need help with codes
Old Aug 5, 2006 | 10:36 PM
wolfman04's Avatar
wolfman04
Default Need help with codes
I keep getting two codes one is BO361 H C Left Actuator Feedback Short to GND and BO441 H C Left Actuator Out of Range can anyone tell me what they mean? I know that H stands for history and C is for current.
Old Aug 6, 2006 | 07:15 AM
Silver98's Avatar
Silver98
The B0361 is:
The HVAC control head receives a LH electric actuator position signal from the LH electric actuator. The LH act. position sensor is a potentiameter that is tied to a 5V reference source... The signal is used to determine the necessary drive signal to the electric actuator motor to provide the proper air mix door position.
The B0441 is:
Conditions to set this include: a damaged or bound up temp door mechanism; improper alignment of the temp door after electric act. replacement; the electric actuator has not been initialized after replacement; During initialization, the position feedback reading is not within an acceptable range
Old Aug 6, 2006 | 10:24 PM
wolfman04's Avatar
wolfman04
Thanks Silver98 for the info.
Old Aug 7, 2006 | 10:38 PM
JR_VETTE's Avatar
JR_VETTE
Mid-TN Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Try disconnecting the battery. That will force a recalibration of the HVAC doors.
Old Aug 9, 2006 | 08:30 AM
foremaw's Avatar
foremaw
Active Streak: 90 Days
St. Jude Donor '08-'09-'10-'11-'12
See this link:
http://forums.corvetteforum.com/show....php?t=1465931
To Need help with codes
