Lunati cam's
Old Aug 12, 2006 | 07:47 PM
dwarmenzerk's Avatar
dwarmenzerk
Default Lunati cam's
has anyone ever heard of them.. i have a wesbite saying it will fit in an ls1 vette..
uh.. im not sure.. send me some help this way.
good way to go for a different cam?
Old Aug 12, 2006 | 07:53 PM
Sales@HPE's Avatar
0Sales@HPE
Former Vendor
No, stay away from them... They don't make good power for their size. You will be much better off with a Comp XER lobed cam.
Chuck @ HPE
281-448-1300
Horsepower Engineering
Mon-Fri: 9-7
Closed Weekends
Old Aug 12, 2006 | 11:59 PM
willyfastz's Avatar
willyfastz
Yes they have LSX cams that work really good, even the 212/218 .531/.531 113/109 made over 30hp.
Old Aug 13, 2006 | 09:31 AM
JoeyG's Avatar
JoeyG
Cruise-In III Veteran
Cruise-In IV Veteran
Chuck @ HPE
281-448-1300
Mon-Fri: 9-7
Closed Weekends
Huh?
Lunati cams have made good power. Like the MTI C1, C2, R1. Some of the Texas Speed Cams were Lunati for awhile, not to mention numerous other vendors who have used them in the past.
Old Aug 13, 2006 | 07:34 PM
vettenuts's Avatar
vettenuts
Lunati has been around for quite a while, what cam in particular are you looking at? Some of their recent grinds are supposed to be pretty good.
Old Aug 13, 2006 | 10:00 PM
dwarmenzerk
i wasnt lookin for anything in particular, but i saw them and wasnt sure if they were any good...
maybe recommend a decent cam with a good lobe?.. give me more power of course
Old Aug 13, 2006 | 10:05 PM
vettenuts's Avatar
vettenuts
Depends on where you want power, what you want for idle, how much maintenance are you willing to do (spring changes, etc.) if you have emissions testing to pass. Lots of factors come into play when selecting a cam because the wrong one can make the car less fun depending on your goals. For example, if you want to maintain a good idle then a cam with a lot of overlap will be lumpy when idling.
Old Aug 13, 2006 | 10:12 PM
dwarmenzerk
lets see.. i dont want a heavy idle, i will change the springs and anything else that i need to do for the initial install.. other than that l have no emmissions, and have no clue what i want and or need ;(
Old Aug 23, 2006 | 12:38 PM
torchredfrc's Avatar
torchredfrc
I'm running a Lunati cam & loving every minute of it.
224/224 .576/.576 112LSA is what I'm running. It's a MTI C2 cam.
As a side note, MTI did not send me the cam I ordered and I did not notice this was the case until having some head work done and the engine builder asked me what cam I'm running so as to avoid any problems with piston to valve clearance. Not much MTI could do at this point but it still sucked to find out that his happened. The C2 cam I ordered was supposed to be 224/224 .581/.581 112LSA.
Old Aug 23, 2006 | 02:15 PM
ALLEGRO's Avatar
ALLEGRO
Lunati is a big name in Pro Stock and Pro Street racers.
Been around since the 60's and I believe they were made in Memphis.
Sold to Holley a few years back as part of their performance family.
I think they are reputable.....JMHO
Old Aug 23, 2006 | 03:57 PM
willyfastz's Avatar
willyfastz
The Lunati Voodoo 212/218 .531/.531 113/109 is a very good cam last one I sold made around 30hp in a 5.3. It doesn't require tuning and will work with a stock converter.
To Lunati cam's
