* * * Regular Maintainance / Servicing Question ? * * *
My car 99, A4 coupe is reaching 25K mile mark soon. I have already changed the tranny fluid & filter at 20K. I do regular oil changes with Mobile1 and K&N filter. Is there something I need to do at this point? I was considering Decarbonization, and change of spark plugs to NGK TR55's, and probably stay with factory wires for now, until I switch to MSD wires later. I'm having the rear diff changed to 3.42 and will add Redline oil in it.
Plz suggest what else I should do, or consider doing. Car doesn't get driven daily, but 3-4 times a weeks.
Thanks... I'll appreciate all suggestions and input...
If the tires are original check them carefully for sidewall cracking. Tires have a time limit on them regardless of wear (I found out the hard way on my boat trailer's tires at 70 mph!
).HTH, and have a good one,
Mike
Mike
The Coolant has also been changed, forgot to mention. Also got a new battery. Tires will be changing soon, once I figure out if I'm gonna keep my Mag wheels or switch to C6 Z06 wheels, then I'll get the new tires also. I don't know how to change the brake fluid, someone had mentioned the speedbleeders, so I'll look into that (though not sure how to do it)
Any other fluids, or anything else needs changing. Car IS AFTER ALL 7 yrs old.
So, I guess I should leave the plugs as they are, not change em? I was under the impression the TR55's have a better spark, therefore better gas burning and some added performance.... Oh well.... I'm open to suggestions..
. I'd love to change the fuel filter also, but I hear its inside the fuel tank. Too much work to get there..
One other thing I'd change at this point would be the fuel and air filters. They're probably OK, but it wouldn't hurt.
Mike
