Brake Fluid Question...
Old Aug 14, 2006 | 09:29 PM
Red903L's Avatar
Red903L
Default Brake Fluid Question...
My C5 is 8 years old next month and has 65K on it and I've accumulated all the parts for a complete brake overhaul. (DuraStop rotors & pads, new GM rubber brake hoses , and a DupliColor paint job on the rotor hats and calipers, etc...)
As part of this overhaul, I'm going to replace all the old brake fluid and herein lies my question. I have no problem using the same stuff GM put in at the factory, as it served me well for many years, BUT....is there better stuff out there that is in the price range of the original GM juice??
Thanks in advance.......
Old Aug 14, 2006 | 09:54 PM
ErnieN85's Avatar
ErnieN85
Valvoline synthetic DOT4
stay away from the DOT5 as it isn't compatible with ABS
Old Aug 14, 2006 | 10:33 PM
Red903L's Avatar
Red903L
Thanks........
I thought I had read something about the Valvoline stuff being pretty good, but wasn't sure!
Old Aug 15, 2006 | 12:41 AM
rws.1's Avatar
rws.1
Valvoline Synpower synthetic formula brake fluid is a borated ester that is DOT 3 and DOT 4.
It has higher boiling point and less water absorption than a ester based DOT 3 fluid.,
I have been using it for over 2 years in my Vettes
Old Aug 15, 2006 | 07:47 AM
BobbyG's Avatar
BobbyG
St. Jude Donor '06-'07
It's what I use also and it's readily available.
Old Aug 15, 2006 | 08:20 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
The valvoline is good for everyday driving. If you plan to track your car then you will have to upgrade to something with a higher dry and wet boiling point.
I run ATE Super Blue Racing all year now.
As noted stay away from DOT 5.
BTW if you have a MN6 this would be a good time to also clean out your clutch reservoir and replace with the Valvoline.
Old Aug 15, 2006 | 09:30 AM
jovette's Avatar
jovette
I assume the Valvoline DOT 4, synthetic is compatible with the OEM DOT 3, is that correct?
Old Aug 15, 2006 | 11:35 AM
ErnieN85's Avatar
ErnieN85
Yes
Old Aug 15, 2006 | 11:48 AM
AU N EGL's Avatar
AU N EGL
I use Castol LMA ( Low Moisture Absorbption) in my Pick-up and wifes vette. Castol SRF in the track vette.
Old Aug 15, 2006 | 01:17 PM
Barrier's Avatar
Barrier
You might want to try Ford High Performance Brake Fluid.
I know..I know!
Used by a lot of Motor Home guys and Racers due to High Boiling point, wet and dry, over standard fluid.
Price is right as well. Makes you not mind discarding 3/4 full opened container.
Barrier
To Brake Fluid Question...
