Brake Fluid-
Old Aug 15, 2006 | 10:38 AM
VatorMan's Avatar
VatorMan
CI 6-7-8 Veteran
St. Jude's Donor '06-'10-'11, '15
Default Brake Fluid-
Cap says use DOT 3-however I've been told to use DOT 5 due to my (ahem) spirited driving habits. Any advice?
Old Aug 15, 2006 | 10:43 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Never Use Dot 5 - End Of Discussion
Old Aug 15, 2006 | 10:46 AM
Wicked Weasel
BTW if you need better fluid because you are hard on your brakes then you can move up to a racing fluid that has better wet and dry boiling points.
I run ATE Super Blue Racing fluid with Racing Brake Pads and never experience brake fade.
I would think though Valvoline Synthetic Dot 3-4 is good enough for most street driving even some aggressive driving.
Make sure to bleed your entire system when putting new in.....
Old Aug 15, 2006 | 10:47 AM
WNDOPDLR's Avatar
WNDOPDLR
Get off the DOT 5 and use a quality(hi wet boiling point) fluid like Motul. I don't know of any of the track guys who would even consider using DOT 5 and the car would probably be rejected in tech inspeciton if it were know that DOT 5 was in use.
Old Aug 15, 2006 | 11:51 AM
AU N EGL's Avatar
AU N EGL
Never DOT 5. Only Dot 3 or DOT4.
Dot 5 is silicone based and does not lubricate teh ABS system. and when water gets into the brake system if forms little bubbles and foams up when hot. Your bakes go . . . . . and you in your car go
Old Aug 15, 2006 | 01:23 PM
VatorMan's Avatar
VatorMan
CI 6-7-8 Veteran
Thanks guys !!!
Old Aug 15, 2006 | 03:25 PM
rws.1's Avatar
rws.1
Buy a DOT 3 and DOT 4 product. these borated esters have higher boiling poiints and absorb less water..
For price and availability you cannot beat Valvoline Synpower
Old Aug 15, 2006 | 07:13 PM
cruisemon's Avatar
cruisemon
Default Actually, when the brakes...
away because the DOT 5 bubbled and compressed, we need an emoticon of a smiley head taking a dump, not banging his head.
Charlie
Old Aug 15, 2006 | 09:16 PM
AU N EGL's Avatar
AU N EGL
Charlie
Well I hope I dont get a warring or the boot for these:
S*** hitting the fan
Others were a bit too . . .
And of course every race likes too see this one
Old Aug 16, 2006 | 10:24 AM
2kbluestreak's Avatar
2kbluestreak
Congratulations on seekiing advice on this forum: that's what it's for. We should all take heart and not automatically and blindly follow advice on any subject given by a person, whenever we do not absolutely know how much expertise he has on the subjcet.
To Brake Fluid-
