Fan Blower Problems
Old Aug 15, 2006 | 03:26 PM
RicksRedVette's Avatar
RicksRedVette
Default Fan Blower Problems
Help!!
The climate control fan on my '00 coupe seems to be running, but I have little if any, air blowing thru the vents. I can hear the fan running, but the noise doesn't match the volume of air I'm getting. The problem appears to occur in both a/c and heater modes. Any ideas??
Old Aug 15, 2006 | 10:51 PM
Oldvetter's Avatar
Oldvetter
Have you removed your intake manifold recently? Does air come out of the correct place for A/C, Heat, Defrost ? There is a very small (soda straw size) vacuum hose at the rear of the intake manifold, it supplies vacuum to move air doors in the HVAC system.
Old Aug 15, 2006 | 11:17 PM
RicksRedVette
You, dear sir, have hit the proverbial nail on the head. I recently replaced the oil sensor.... Thanks for the input!! This, coupled with a similar thread should allow me to address the issue this coming weekend. Thanks Again!
Old Aug 15, 2006 | 11:28 PM
Oldvetter's Avatar
Oldvetter
It is very hard to get on, you have to "feel it". Some people add a rubber hose extension, check out this thread:
http://forums.corvetteforum.com/show....php?t=1472249
Good Luck !
To Fan Blower Problems
