Tire size question
Old Aug 15, 2006 | 05:31 PM
Triple Black 1999's Avatar
Triple Black 1999
Default Tire size question
I'm about to replace the tires on my '99 roadster. Currently I'm using the original runflats on polished OEM '00 wheels. I'm considering upsizing to 295/35-18 Goodyear F1-GSD3s on the rear...Does anyonone know if these will fit correctly?
Andrew
Old Aug 15, 2006 | 05:48 PM
LoneStarFRC's Avatar
LoneStarFRC
No worries. Excellent tire choice too.
Old Aug 15, 2006 | 08:43 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
This subject has come up here a lot. Many people will tell you that a 295/35-18 tire will fit fine on the stock Y2k rims (9.5" wide).
I look at it this way...
GM's interest is maximizing profit margin, consistent with providing a safe vehicle. There has to be a reason they provided 10.5" wheels for that size on the Z06. Also look at what the tire mfg says. Remember that their interest is in selling tires. They don't do that by telling you that a combination of tire/wheel is incompatible if it's not. Note that they recommend 10" as the minimum wheel diameter to mount this tire:
http://www.goodyeartires.com/goodyea...8&sidewall=VSB
Caveat emptor - you decide.
Old Aug 15, 2006 | 10:10 PM
Kebrock's Avatar
Kebrock
St. Jude Donor '11
I've got them, no problems and they look good
Old Aug 15, 2006 | 10:24 PM
HIRISC's Avatar
HIRISC
St. Jude Donor '06
Any close-up pics??
Old Aug 15, 2006 | 11:15 PM
Kebrock's Avatar
Kebrock
St. Jude Donor '11
This is the closest pic I have of the rear tire...hope it'll do On a side note, the fronts are too big (275's).
They were on the car when I bought it. They're too wide and tall looks wise. If I had the spare $$, I would replace them.
Old Aug 15, 2006 | 11:43 PM
wamara's Avatar
wamara
Cruise-In II Veteran
Andrew,
They will fit, although "correctly" is subject to debate/interpretation. I would simply opine that the 295 tire width is not optimal for a 9.5" wheel width.
Old Aug 16, 2006 | 12:06 AM
EHS's Avatar
EHS
I would recommend getting wheels to go with the F1-GSD3s. It's an expensive tire -- don't be cheap with the assembly.
Or, get some non-run flats in a size that's appropriate for the wheels you have.
Old Aug 16, 2006 | 08:34 AM
Darion's Avatar
Darion
Originally Posted by wamara
Andrew,
Old Aug 16, 2006 | 09:32 AM
Clay Assassin's Avatar
Clay Assassin
Ive been running 315's on my C4 9.5" rims for over 12 years.
I have the same tires your looking at now. 315's stick out quite a bit from the rim, but I have not had any problems with the tire/rim set up.
Old Aug 16, 2006 | 09:58 AM
HIRISC's Avatar
HIRISC
St. Jude Donor '06
BADA$$ looking FRC!
Were your thin spokes once chrome and now powdercoated??
Old Aug 16, 2006 | 09:59 PM
Kebrock's Avatar
Kebrock
St. Jude Donor '11
Originally Posted by HIRISC
BADA$$ looking FRC!
Thanks!
I'm not for sure which they were...they were like that when I bought the car, which was nice cause I wanted to paint or powdercoat them anyways.
Old Aug 17, 2006 | 02:44 AM
Silver Z06 Driver's Avatar
Silver Z06 Driver
I also had 315 35 17's on a 9.5 inch rims on my old 96 Vette...... I SCCA aotocrossed the crap out of them in VERY hard turns and spinouts and NEVER poped a bead!!!!
Old Aug 17, 2006 | 03:06 AM
jdmvette's Avatar
jdmvette
Night Owl for life
those tires have gotta stick out like:
Old Aug 17, 2006 | 04:50 AM
EHS's Avatar
EHS
Obviosuly, not hard enough....
And the added benefit is that you've probably never scraped a rim on a curb.
Excellent!
Old Aug 18, 2006 | 12:59 AM
Triple Black 1999
Thanks for the input, guys. I ended up switching gears and going for Nitto NT555s in the factory sizes. Should have them tomorrow...I'll share some feedback once they're on.
To Tire size question
