car keeps going into limp mode
Old Aug 22, 2006 | 04:46 PM
pdd000's Avatar
pdd000
Originally Posted by see5
TPS should throw a code. I just don't understand no code????????????????????
no code
Old Aug 22, 2006 | 04:59 PM
see5's Avatar
see5
Originally Posted by pdd000
no code
Ok, so if you:
turn on key, don't start engine
press and hold reset till it does
Then
hold options while pressing fuel 4 times
You see 10-PCM-No codes??
Old Aug 22, 2006 | 06:10 PM
pdd000's Avatar
pdd000
Ok, so if you:
Then
i just went through them all today, here are my codes but i cant rememeber if there were any in the 10-pcm, but ill check when i get home from work
codes are
p1515 h - control module throttle acuator postion performance
p1516 h- throttle acuator control
p1626 h- theft deterrent fuel enable signal
p1638 h c - generator
c1278 h- tcs-temporarily inhibited
c 594 h c- right rear solinoid open
u 1096 h
u 1064 h
u 1016 h
u 1160 h
c 2120 h c tire pressure
the p1638 h c is the generator- i installed a 200 amp alt three years ago and always got this code ever since with no issues
c2120- i have no tire pressure gauges-never an issue in years
the u codes are from dissconnecting the battery.
Old Aug 23, 2006 | 02:43 AM
kendo347's Avatar
kendo347
Have you checked/cleaned the connections to the tac module? May be a bad connection. Also check the fuses.
Old Aug 23, 2006 | 01:24 PM
HRDTOPC54FUN's Avatar
HRDTOPC54FUN
This may not help but for what it's worth, I had a similar problem last winter after installing a new Callaway TB. Turned out to be a bad throttle position sensor. The sensor checked out ok electrically but apparantly had a discontinuity somewhere between idle and wot (this was a brand new GM TPS). Sorry, I don't remenber the codes I had.
Replacing the TPS solved the prob.
May not be your prob but it's a relatively cheap part and easy to install.
Just my .02.
Old Aug 23, 2006 | 01:35 PM
Ls1cobra's Avatar
Ls1cobra
Navigator
Your problem is P1626. this is the only one on there that will put the engine in limp mode. Read the service manuals on the engine section page 426 ( tope left).
Old Aug 23, 2006 | 03:10 PM
pdd000's Avatar
pdd000
even though it says 'H 'for history
Old Aug 23, 2006 | 03:19 PM
see5's Avatar
see5
Yes- if it were C you would be limping.
I have been there with LS2TB. Turned out to be wiring to TB.
This will isolate it if you have a meter:
http://www.gearchatter.com/viewtopic10138.php
Old Aug 23, 2006 | 03:36 PM
pdd000's Avatar
pdd000
well i checked the throttle body blade. opens perfect with the car off when i floor it
Old Aug 23, 2006 | 03:37 PM
pdd000's Avatar
pdd000
that might be a little over my head i installed everything but when it comes to wiring and voltage im confused
Old Aug 23, 2006 | 04:15 PM
see5's Avatar
see5
The blade opening may be fine but if the TPS is not seeing what it expects it goes to limp to protect you from stuck or malfunctioning throttle.
