Vacuum line behind intake
Old Aug 17, 2006 | 10:56 PM
Turbosixx's Avatar
Turbosixx
Default Vacuum line behind intake
I'm in the process of changing my heads, cam and intake. While I was taking the passenger side head off I noticed a small plastic vacuum line going inside the big harness bolted to the back of the passenger side head. I did not unplug this line so it must have come disconnected when I was removing the intake, or it wasn't connected to anything. Where does this line go?
Old Aug 17, 2006 | 11:12 PM
berryj's Avatar
berryj
It may be this line shown in my post here:
http://forums.corvetteforum.com/show....php?t=1472249
I have a piece of rubber tubing attached to it. The stock "straw" is black hard plastic which attaches to the small rubber elbow on the back of your intake manifold. However, I don't know where the other end of that straw goes after it dips behind the engine.
Old Aug 17, 2006 | 11:17 PM
vette747's Avatar
vette747
This is to open and closed the HVAC AC doors.
Comments in red talk about this hose:
And the other end it connects to:
Old Aug 17, 2006 | 11:28 PM
Turbosixx's Avatar
Turbosixx
HA! I didn't notice when I pulled the intake. I would have been mad if the A/C didn't work. You guys rock!
Old Aug 18, 2006 | 06:05 AM
Blow Torch's Avatar
Blow Torch
[QUOTE=vette747]This is to open and closed the HVAC AC doors.
I "extended" mine on both cars (learned from the 1st) with some additional line (approx. 4") so I could hook it up before sliding the manifold back in place. It is a PITA to hook up once the intakle is back!
Old Aug 18, 2006 | 06:14 AM
vettenuts's Avatar
vettenuts
Need small hands, this is where kids and the wife can help
Old Aug 18, 2006 | 06:28 AM
WKMCD's Avatar
WKMCD
[QUOTE=BOTTLE FED]
Extend it....You've been warned!
Old Aug 19, 2006 | 09:41 AM
Varmit's Avatar
Varmit
St. Jude Donor '08
Will this cause a rough idle if there is a problem with it???
Old Aug 19, 2006 | 07:10 PM
VetteTech81's Avatar
VetteTech81
Meaning if there was a leak in the line or if the line was disconnected... yes very possible... you would have false air entering the intake, meaning air that the PCM can't see through the MAF sensor.... I've see the intake bellows/accordian tube after the maf has a small tear in it and it would cause the car to run rough.. and sometimes the rough condition would come and go supraticly since the tube was flexing...
-=Rick
Old Aug 19, 2006 | 07:16 PM
cruisemon's Avatar
cruisemon
Default Rough idle is almost certain...
But that is NOTHING compared to language which shall emanate from the passenger compartment upon discovering the AC she's a no work. Some may be able to reach this *^#%@( tube after you put the (*&^#% manifold back on the &%(*^#$ engine but my hands are too (*^&#%^ big to do it.
Charlie
Old Aug 19, 2006 | 09:35 PM
berryj's Avatar
berryj
I haven't had any problems w/ my extension. I made it just long enough as you can see in my picture via the link above in my post. When I push the manifold into position there is no kinking/leaking. I've had it like this for over 3 months, no problem.
Old Aug 20, 2006 | 03:23 PM
corvette Mark's Avatar
corvette Mark
This information is GOLD for all of us who like to work on our own cars.
Thanks for posting!!!
Old Aug 20, 2006 | 05:36 PM
vette747's Avatar
vette747
Glad I could help. If you want some more, I have about 30 DIY on my web site.
http://pages.videotron.com/vette747/
Old Aug 20, 2006 | 09:31 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
My 98 had the HVAC quit working and I traced it down to that fitting coming off the intake. Man talk about a pain in the *** to get back on. A mirroe, lond needle nose plires and lots of cursing but I got it back on. YES,,, I added an extension hose!!!
Here are some more pics fr=or your files! Isave them all!!!
Here is the vacuum resivour that it goes to!
Hope that helps!
Bill Curlee
Old Aug 20, 2006 | 11:48 PM
SpeedyZ's Avatar
SpeedyZ
As other here has said that hose goes to the vacuum reservoir tank in the right fender well. Here is a photo of the tank and hoses, the manifold hose enters at the bottom.
Old Oct 30, 2024 | 10:23 PM
Littleman55's Avatar
Littleman55
[img alt="Does anyone know how to fix this problem whit my 2003 corvette
"]https://cimg5.ibsrv.net/gimg/www.corvetteforum.com-vbulletin/2000x1504/img_0766_b5a85654619adf2e0746ba05cd5d4ed 35ec32c5e.jpeg[/img]
Old Oct 31, 2024 | 07:41 AM
lucky131969's Avatar
lucky131969
I believe you are in the running for the thread resurrection award this week......18 years old ! ...........but.....what does your fuel sending unit issue have to do with the intake manifold vacuum hose?
To Vacuum line behind intake
